楼主 |
发表于 2014-4-15 15:52:40
显示全部楼层
回复 2# jamesccp
我知道是压控电阻,我看了hspice用户手册
NPWL Function
For node ‘in- ‘connected to ‘n-’;
If v(n+,n-) > 0, then the controlling voltage would be v(in+,in-). Otherwise,
the controlling voltage is v(in+,n+)
For node ‘in-’connected to ‘n+’;
If v(n+,n-) < 0, then the controlling voltage would be v(in+,in-). Otherwise,
请问上述程序中的VOLTAGE指的就是这个控制电压吗?我仿照着试了一下,好像不太对 |
