查看: 4969|回复: 2
[讨论] ICC:NO valid link library found
发表于 2014-4-9 10:18:18 | 显示全部楼层 |阅读模式
Warning: No valid link library found,please specify link_libray.
请教:链接库是哪些文件?里面定义的是什么?怎样链接?
发表于 2014-4-9 13:18:46 | 显示全部楼层
IC Compiler uses the “link library” to resolve all the instantiated components in a netlist. A netlist is resolved if IC Compiler finds a corresponding library cell (in any of the specified link_library files) for each leaf cell that is instantiated in the netlist, as well as a corresponding design in IC Compiler memory (that’s what the * represents) for each sub-design in the netlist. This “resolving” happens when the netlist is read in (described in a few pages).
发表于 2016-11-6 01:13:56 | 显示全部楼层
回复 1# severdesigner
在使用ICC时,我也看到了这样的warning
icc_shell> open_mw_cel dfm
Warning: No valid link library found, please specify link_library. (IFS-008)
解决的办法是,在导入你的设计前,先将需要的library导入ICC,
# Standard cell lib
set_min_library ${synopsys_max_db_name}.db -min_version ${synopsys_min_db_name}.db
# iopad lib
set_min_library ${iopad_max_db_name}.db    -min_version ${iopad_min_db_name}.db
# SRAM macro lib
set_min_library ${ibm_sram_max_db_name}.db -min_version ${ibm_sram_min_db_name}.db
然后再打开design就没有告警了
GMT+8, 2025-9-14 22:15 , Processed in 0.015676 second(s), 8 queries , Gzip On, Redis On.
