查看: 3421|回复: 2
VCS compilation setup failed 有没有大神指导啊
发表于 2014-4-6 23:03:54 | 显示全部楼层 |阅读模式
Got SIGSEGV
An unexpected termination has occurred in /home/nario/synopsys/vcs/amd64/bin/vcs1
During setup for compilation
Command line: /home/nario/synopsys/vcs/amd64/bin/vcs1 -Mcc=gcc -Mcplusplus=g++ -Masflags= "-Mcfl= -pipe -O -I/home/nario/synopsys/vcs/amd64/lib " "-Mldflags= -melf_i386 " -Mout=simv -Mamsrun= -Mvcsaceobjs= "-Mobjects= /home/nario/synopsys/vcs/amd64/lib/libvirsim.so /home/nario/synopsys/vcs/amd64/lib/liberrorinf.so /home/nario/synopsys/vcs/amd64/lib/libsnpsmalloc.so " -Msaverestoreobj=/home/nario/synopsys/vcs/amd64/lib/vcs_save_restore_new.o -Mcrt0= -Mcrtn= -Mcsrc= "-Msyslibs=/home/nario/synopsys/vcs/amd64/lib/ctype-stubs_32.a -ldl " -gen_obj top.v
--- Stack trace follows:
ptrace: Operation not permitted.
/home/nario/proj/58538: No such file or directory.
No stack.
/tmp/vcs_20140406150433_58416/.stack_annotator_gdb_cmd_file_DZNdHR:3: Error in sourced command file:
The program is not being run.
Completed context dump phase
CPU time: 2.999 seconds to compile
发表于 2014-7-15 19:27:34 | 显示全部楼层
我也遇到同样的问题,请问这个问题解决了吗?
发表于 2014-9-22 15:38:30 | 显示全部楼层
回复 1# rod_home
   请问现在是如何解决的啊?也碰到这个问题了。
GMT+8, 2025-12-26 05:41 , Processed in 0.014623 second(s), 5 queries , Gzip On, Redis On.
