查看: 3228|回复: 0
[求助] 紧急求助
发表于 2014-4-3 21:35:21 | 显示全部楼层 |阅读模式
悬赏50资产未解决
安装ic610时在installscape时如下提示,系统位ubuntu12.04LTs
Type the path to InstallScape installation directory [ (q to quit)]: /home/eda/installscape
InstallScape installation directory: /home/eda/installscape
Extracting InstallScape version 03.40.p06
for platform lnx86 in /home/eda/installscape
Starting up InstallScape in GUI mode
DISPLAY environment variable is set to :0.0
If you do not see the InstallScape console
window or the it seems to be hanging then kill this
process.
Set your DISPLAY environment variable to a proper
value and manually start InstallScape by typing:
/home/eda/installscape/iscape/bin/iscape.sh /home/eda/IC610_lnx86.Base/CDROM1:::/home/eda/ic610
Initializing InstallScape using JVM at /home/eda/installscape/iscape/runtime/LNX86/bin/java. This might take some time...
Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/eda/installscape/iscape/runtime/LNX86/lib/i386/libawt.so: libXp.so.6: cannot open shared object file: No such file or directory
    at java.lang.ClassLoader$NativeLibrary.load(Native Method)
    at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1586)
    at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1503)
    at java.lang.Runtime.loadLibrary0(Runtime.java:788)
    at java.lang.System.loadLibrary(System.java:834)
    at sun.security.action.LoadLibraryAction.run(LoadLibraryAction.java:50)
    at java.security.AccessController.doPrivileged(Native Method)
    at java.awt.Toolkit.loadLibraries(Toolkit.java:1437)
    at java.awt.Toolkit.<clinit>(Toolkit.java:1458)
    at com.khanpur.installer.gui.InstallerUI.main(InstallerUI.java:70)
happysingle@ubuntu:/home/eda/IC610_lnx86.Base/CDROM1$
请问是什么问题
GMT+8, 2025-9-14 11:32 , Processed in 0.014471 second(s), 5 queries , Gzip On, Redis On.
