查看: 2628|回复: 0
[求助] 请大神指点下 ISE14.2 用其自带的仿真软件进行仿仿真问题
发表于 2014-4-3 17:04:55 | 显示全部楼层 |阅读模式
本人在VHDL方面是小白,下面的程序的激励信号怎么添加啊?
源程序:LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
USE IEEE.STD_LOGIC_ARITH.ALL;
ENTITY PWM IS
PORT(
     CLK:IN STD_LOGIC;
     D  :IN STD_LOGIC_VECTOR(11 DOWNTO 0);
     A  :OUT STD_LOGIC_VECTOR(11 DOWNTO 0);
     PWMH:OUT STD_LOGIC;
     PWML:OUT STD_LOGIC
END;
ARCHITECTURE BEHAVE OF PWM IS
SIGNAL PH:STD_LOGIC;
SIGNAL PL:STD_LOGIC;
SIGNAL COUNTH :STD_LOGIC_VECTOR(11 DOWNTO 0);
BEGIN
PROCESS(CLK)
BEGIN
IF CLK'EVENT AND CLK='1' AND CLK'LAST_VALUE='0' THEN
                          COUNTH<=COUNTH+'1';
       IF COUNTH="000000001111" THEN COUNTH<="000000000000";
       END IF;
END IF;
IF COUNTH<=D THEN PH<='1'; PL<='0';
ELSIF COUNTH>D THEN     PH<='0'; PL<='1';
END IF;
END PROCESS ;
PWMH<=PH;
PWML<=PL;
A<=COUNTH;
END;
测试平台程序:
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
ENTITY test IS
END test;
ARCHITECTURE behavior OF test IS
    COMPONENT PWM
    PORT(
         CLK : IN  std_logic;
         D : IN  std_logic_vector(11 downto 0);
         A : OUT  std_logic_vector(11 downto 0);
         PWMH : OUT  std_logic;
         PWML : OUT  std_logic
    END COMPONENT;
   --Inputs
   signal CLK : std_logic := '0';
   signal D : std_logic_vector(11 downto 0) := (others => '0');
  --Outputs
   signal A : std_logic_vector(11 downto 0);
   signal PWMH : std_logic;
   signal PWML : std_logic;
   -- Clock period definitions
   constant CLK_period : time := 10 ns;
BEGIN
-- Instantiate the Unit Under Test (UUT)
   uut: PWM PORT MAP (
          CLK => CLK,
  1. 本人在VHDL方面是小白,下面的程序的激励信号怎么添加啊?
  2. 源程序:
  3. LIBRARY IEEE;
  4. USE IEEE.STD_LOGIC_1164.ALL;
  5. USE IEEE.STD_LOGIC_UNSIGNED.ALL;
  6. USE IEEE.STD_LOGIC_ARITH.ALL;
  7. ENTITY PWM IS
  8. PORT(
  9.      CLK:IN STD_LOGIC;
  10.      D  :IN STD_LOGIC_VECTOR(11 DOWNTO 0);
  11.      A  :OUT STD_LOGIC_VECTOR(11 DOWNTO 0);
  12.      PWMH:OUT STD_LOGIC;
  13.      PWML:OUT STD_LOGIC
  14.      );
  15. END;
  16. ARCHITECTURE BEHAVE OF PWM IS
  17. SIGNAL PH:STD_LOGIC;
  18. SIGNAL PL:STD_LOGIC;
  19. SIGNAL COUNTH :STD_LOGIC_VECTOR(11 DOWNTO 0);
  20. BEGIN
  21. PROCESS(CLK)
  22. BEGIN
  23. IF CLK'EVENT AND CLK='1' AND CLK'LAST_VALUE='0' THEN
  24.                           COUNTH<=COUNTH+'1';
  25.        IF COUNTH="000000001111" THEN COUNTH<="000000000000";
  26.        END IF;
  27. END IF;
  28. IF COUNTH<=D THEN PH<='1';PL<='0';
  29. ELSIF COUNTH>D THEN     PH<='0'; PL<='1';
  30. END IF;
  31. END PROCESS ;
  32. PWMH<=PH;
  33. PWML<=PL;
  34. A<=COUNTH;
  35. END;
  36. 测试平台程序:
  37. LIBRARY ieee;
  38. USE ieee.std_logic_1164.ALL;
  39. -- Uncomment the following library declaration if using
  40. -- arithmetic functions with Signed or Unsigned values
  41. --USE ieee.numeric_std.ALL;
  42. ENTITY test IS
  43. END test;
  44. ARCHITECTURE behavior OF test IS
  45.     -- Component Declaration for the Unit Under Test (UUT)
  46.     COMPONENT PWM
  47.     PORT(
  48.          CLK : IN  std_logic;
  49.          D : IN  std_logic_vector(11 downto 0);
  50.          A : OUT  std_logic_vector(11 downto 0);
  51.          PWMH : OUT  std_logic;
  52.          PWML : OUT  std_logic
  53.         );
  54.     END COMPONENT;
  55.    --Inputs
  56.    signal CLK : std_logic := '0';
  57.    signal D : std_logic_vector(11 downto 0) := (others => '0');
  58.   --Outputs
  59.    signal A : std_logic_vector(11 downto 0);
  60.    signal PWMH : std_logic;
  61.    signal PWML : std_logic;
  62.    -- Clock period definitions
  63.    constant CLK_period : time := 10 ns;
  64. BEGIN
  65. -- Instantiate the Unit Under Test (UUT)
  66.    uut: PWM PORT MAP (
  67.           CLK => CLK,
  68.           D => D,
  69.           A => A,
  70.           PWMH => PWMH,
  71.           PWML => PWML
  72.         );
  73.    -- Clock process definitions
  74.    CLK_process :process
  75.    begin
  76.   CLK <= '0';
  77.   wait for CLK_period/2;
  78.   CLK <= '1';
  79.   wait for CLK_period/2;
  80.    end process;
  81.    -- Stimulus process
  82.    stim_proc: process
  83.    begin
  84.       -- hold reset state for 100 ns.
  85.       wait for 100 ns;
  86.       wait for CLK_period*10;
  87.       -- insert stimulus here
  88.       wait;
  89.    end process;
  90. END;
  91. 拜托了!!
    复制代码
          D => D,
          A => A,
          PWMH => PWMH,
          PWML => PWML
   begin
  CLK <= '0';
  CLK <= '1';
   end process;
   END;
拜托了!!
GMT+8, 2025-12-14 11:07 , Processed in 0.015521 second(s), 7 queries , Gzip On, Redis On.
