查看: 2247|回复: 0
[求助] ENCOUNTER保存文件时提示错误
发表于 2014-3-31 22:18:42 | 显示全部楼层 |阅读模式
现把错误粘贴如下:
我惊喜的发现粘出来居然把一部分转成这个了表情了!!!!!,谁遇到过,麻烦帮忙解答下
**ERROR: (SOCSYT-7072):        uiUtil:pen_file failed
    while executing
"error [getError $::uiEmsHandleId 7072 ] "
    ("default" arm line 3)
    invoked from within
"switch -- $arg {
      "-filetypes"   {set opt(types)       $val}
      "-forread"     {set opt(forread)     $val}
      "-initialdir"  {set opt(initi..."
    ("for" body line 11)
    invoked from within
"for {set argc 0} {$argc < $len} {incr argc} {
    set arg [lindex $args $argc]
    incr argc
    if {$argc == $len} {
      putError $::uiEmsHandleId..."
    (procedure "uiUtil:pen_file" line 23)
    invoked from within
"uiUtil::open_file -forread 0 -initialdir /home/yutt/Encounter/byme/fixed/ s35932/k=4 -parent .rda_input -filetypes {{{Input config files} .conf*} {{Al..."
    ("eval" body line 1)
    invoked from within
"eval uiUtil::open_file $args"
    (procedure "Rda_UI::open_file" line 1)
    invoked from within
"Rda_UI::open_file -forread 0 -initialdir /home/yutt/Encounter/byme/fixed/ s35932/k=4 -parent .rda_input -filetypes {{{Input config files} .conf*} {{Al..."
    invoked from within
"eval Rda_UI::open_file -forread 0 -initialdir $input_dir $args"
    invoked from within
"if {[info exists input_dir]} {
    return [eval Rda_UI::open_file -forread 0 -initialdir $input_dir $args]
  } else {
    return [eval Rda_UI::open_fi..."
    (procedure "get_save_file" line 4)
    invoked from within
"get_save_file -parent $w -filetypes $types -title "Save Input Configuration"  -initialfile [::Rda_Util::designName].conf"
    (procedure "::Rda_Design::Input::save" line 3)
    invoked from within
"::Rda_Design::Input::save rda_Input .rda_input"
    invoked from within
".rda_input.save invoke"
    ("uplevel" body line 1)
    invoked from within
"uplevel #0 [list $w invoke]"
    invoked from within
"if { $Priv(repeated) == 0 } {
    invoked from within
"if {$Priv(window) eq $w && [$w cget -state] ne "disabled"} {
            # Only invoke the command if it wasn't already invoked by the
            # auto-repeater f..."
    invoked from within
"if {[string equal $w $Priv(buttonWindow)]} {
        set Priv(buttonWindow) ""
        # Restore the button's relief if it was cached.
        if {[info exists Priv($w,r..."
    (procedure "tk::ButtonUp" line 3)
    invoked from within
"tk::ButtonUp .rda_input.save"
    (command bound to event)
GMT+8, 2025-12-25 01:22 , Processed in 0.370711 second(s), 7 queries , Gzip On, Redis On.
