查看: 3831|回复: 1
[求助] ISE implement 遇到了问题
发表于 2014-3-27 17:30:12 | 显示全部楼层 |阅读模式
  1. ERROR:MapLib:979 - LUT2 symbol
  2.    "mysystem/mys_i/proc_sys_reset_0/proc_sys_reset_0/EXT_LPF/External_System_Reset_MB_Debug_Sys_Rst_OR_8_o1" (output
  3.    signal=mysystem/mys_i/proc_sys_reset_0/proc_sys_reset_0/EXT_LPF/External_Syst
  4.    em_Reset_MB_Debug_Sys_Rst_OR_8_o) has input signal "RESET" which will be
  5.    trimmed. See Section 5 of the Map Report File for details about why the input
  6.    signal will become undriven.
  7. ERROR:MapLib:978 - LUT2 symbol
  8.    "mysystem/mys_i/proc_sys_reset_0/proc_sys_reset_0/EXT_LPF/External_System_Reset_MB_Debug_Sys_Rst_OR_8_o1" (output
  9.    signal=mysystem/mys_i/proc_sys_reset_0/proc_sys_reset_0/EXT_LPF/External_Syst
  10.    em_Reset_MB_Debug_Sys_Rst_OR_8_o) has an equation that uses input pin I0,
  11.    which no longer has a connected signal. Please ensure that all the pins used
  12.    in the equation for this LUT have signals that are not trimmed (see Section 5
  13.    of the Map Report File for details on which signals were trimmed).
    复制代码
发表于 2014-3-27 21:44:02 | 显示全部楼层
输入未赋值?
GMT+8, 2025-12-30 07:27 , Processed in 0.013115 second(s), 4 queries , Gzip On, Redis On.
