查看: 5227|回复: 11
A Low-Power High-Performance SiGe BiCMOS 802.11a/b/g
发表于 2007-3-15 16:04:33 | 显示全部楼层 |阅读模式
This paper describes a low-power, high-performance
WLAN 802.11a/b/g radio transceiver optimized for
mobile applications and co-existence with on-board
cellular and Bluetooth systems.
The direct conversion architecture is optimized to achieve
uncompromised RF performance at low power. A key
transceiver requirement is a sensitivity of -77dBm (at the
LNA input) in the presence of a GSM1900 transmitter
interferer while in 54Mb/s OFDM mode. The receiver
chain achieves a NF of 2.8/3.2dB, consuming
168/185mW at 2.8V for the 2.4/5GHz bands respectively.
Signal loopback and transmit power detection techniques
are used in conjunction with the baseband modem
processor to calibrate the transmitter LO leakage and the
transceiver I/Q imbalances. Fabricated in a 70GHz fT
0.25 m SiGe BiCMOS technology for System-in-
Package (SiP) use, the dual-band, tri-mode transceiver
occupies only 4.6mm
01541576.pdf
562.81 KB, 下载次数: 80 , 下载积分: 资产 -2 信元, 下载支出 2 信元
头像被屏蔽
发表于 2007-4-30 06:10:51 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
 楼主| 发表于 2007-8-12 23:23:18 | 显示全部楼层
[quote][/quote]dingqi来
发表于 2007-8-13 05:57:55 | 显示全部楼层
thanks for your information...
thanks...................
发表于 2007-8-15 12:54:13 | 显示全部楼层
发表于 2008-7-21 21:31:42 | 显示全部楼层
xie xie
发表于 2008-11-13 09:44:04 | 显示全部楼层
顶起来 !!!
发表于 2008-11-13 13:50:02 | 显示全部楼层
xie xie
发表于 2014-9-23 22:23:08 | 显示全部楼层
这个是论文吧
发表于 2019-9-15 12:37:57 | 显示全部楼层
非常感謝!!!!!
GMT+8, 2025-12-27 12:26 , Processed in 0.052532 second(s), 8 queries , Gzip On, Redis On.
