查看: 6865|回复: 19
[paper]DESIGN AND ANALYSIS OF LOW POWER LOW PHASE NOISE VCO
发表于 2007-3-15 16:02:34 | 显示全部楼层 |阅读模式
ABSTRACT: In this paper, a novel methodology to implement a LC tank voltage controlled oscillator (VCO) with lower
phase noise is proposed and verified. A relationship between the phase noise, power consumption and the bias current
is fully analysed to improve the performance of the VCO. The architecture of the VCO employs two current mirrors
one at the top of the cross-coupled complementary VCO and the other at the tail end to balance the impedance and give
the exact replica of the current in both the arms of current mirror circuit. The phase noise measured is -110.9 dBc/Hz at
the offset frequency of 100KHz, -126.4 dBc/Hz at 600kHz and -140.5 dBc/Hz at 3MHz from the carrier frequency.
The VCO consumes only 1.72mW of power at 2V supply. Results show that a 33% reduction in power consumption is
achieved as compared to the VCO using a tail current mirror and 46.75% to the VCO without current mirrors.
Conference: MIXDES 2006 Gdynia, POLAND 22 - 24 June 2006
Author. DUDULWAR, K. SHAH, H. LE, J. SINGH(VICTORIA UNIVERSITY, AUSTRALIA)
pankaj_paper.pdf
171.21 KB, 下载次数: 219 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-3-15 23:20:33 | 显示全部楼层
3ks 3ks 3ks 3ks
发表于 2007-3-16 11:23:08 | 显示全部楼层
3ks 3ks 3ks 3ks
发表于 2007-4-9 21:07:25 | 显示全部楼层
thanks a lot
发表于 2007-4-15 00:09:07 | 显示全部楼层
发表于 2007-11-13 22:46:46 | 显示全部楼层
thanks thanks
发表于 2008-7-4 16:16:37 | 显示全部楼层
thanks
thanks
发表于 2008-7-4 16:17:53 | 显示全部楼层
thanks
发表于 2008-10-25 09:57:04 | 显示全部楼层
好东西
发表于 2009-3-31 21:29:14 | 显示全部楼层
xiexie!
GMT+8, 2025-12-27 21:08 , Processed in 0.030500 second(s), 8 queries , Gzip On, Redis On.
