查看: 27883|回复: 13
[求助] 请教---Hspice的RUNLVL=5 与6精度差多少?
发表于 2014-3-17 17:03:47 | 显示全部楼层 |阅读模式
在方Dynamic Latched comparator Vos时,用Hspice 跑3000次MONTE CARLO.
Hspice中.OPTION RUNLVL=5 比 RUNLVL=6的仿真速度快好几倍,但是,不知道精度损失大不大?
发表于 2014-3-21 01:04:46 | 显示全部楼层
没有精度差别,runlvl只是系统程序优先级,精度是由option选项设置的。
回复 支持 0 反对 1
发表于 2014-6-27 15:00:53 | 显示全部楼层
同问,看hspice手册中关于runlvl的设置,1到6精度依次变高,runlvl=0是关闭了这一选项功能,那0和6的精度是哪个高呢?
发表于 2014-6-27 15:32:18 | 显示全部楼层
回复 3# WEN_AMY
When .OPTION RUNLVL=0 is set, HSPICE uses the  traditional control option
values. These values aim for superior accuracy
往后翻了翻,0是精度最高的
发表于 2014-8-13 14:43:55 | 显示全部楼层
RUNLVL = x
Controls the speed and accuracy trade-off.
It canbe set to 0,1,2,3,4,5,6. Higher values of RUNLVL result in higher accuracy and longer simulation times, while lower values give lower accuracy and faster simulation runtimes.
RUNLVL=0 turns off this algorithm.
RUNLVL=1 is the lowest simulation runtime.
RUNLVL=3 is the default (similar to original HSPICE default mode).
RUNLVL=5, 6 correspond to the HSPICE standard accurate mode.
For most circuits, RUNLVL=5 is similar to the HSPICE standard
accurate mode.
发表于 2014-8-13 14:53:52 | 显示全部楼层
RUNLVL = x Controls the speed and accuracy trade-off. It can
standard accurate mode. For most circuits,
accurate mode.
发表于 2015-4-8 10:48:52 | 显示全部楼层
回复 6# 清醒的神话
    1-3 for digital circuit
有辦法 中間 改變 runlvl 嗎
前面如果須要很長 ramp up time ..
是否可以前面降低 accuracy
後面再拉高 ??
发表于 2018-5-16 18:32:47 | 显示全部楼层
GOOD MATERIAL
发表于 2018-5-22 19:37:13 | 显示全部楼层
GOOD MATERIAL
发表于 2018-8-6 19:00:22 | 显示全部楼层
thanks
GMT+8, 2025-12-28 06:26 , Processed in 0.022202 second(s), 6 queries , Gzip On, Redis On.
