查看: 14157|回复: 39
[原创] MIPI M-PHY
发表于 2014-2-27 20:49:21 | 显示全部楼层 |阅读模式
MIPI M-PHY
MIPI M-PHY_specification_v0-80-00.pdf
1.41 MB, 下载次数: 697 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2014-3-3 17:39:20 | 显示全部楼层
下来看看啊
发表于 2014-3-4 07:08:46 | 显示全部楼层
What' mipi ?
 楼主| 发表于 2014-3-8 00:27:48 | 显示全部楼层
回复 3# pupukid
    http://www.mipi.org/
发表于 2014-3-10 01:31:03 | 显示全部楼层
这是哪一版
发表于 2014-3-27 01:14:15 | 显示全部楼层
Reply 1 # ytlin0
    ggggggggggggggggggggggooooooooooooooooo,,,,,,,,,,,,,,,,,,oooooooooooooooo
发表于 2014-5-2 22:15:26 | 显示全部楼层
这个协议好用吗?先谢谢楼主!!!
发表于 2014-5-5 14:56:25 | 显示全部楼层
谢谢,非常好的资料!
发表于 2014-6-7 16:37:25 | 显示全部楼层
WWAGO公司的MIPI M-PHY VIP 可以verify the components interfacing with MIPI M-PHY interface of an IP or  SoC .  可以联系WWAGO-INC公司的销售,申请免费试用。
该MIPI M-PHY VIP 主要features:
• Compliant to MIPI M-PHY Version 2.0.
• M-PHY Supports two Sub-links.
• Supports high speed and low speed mode for all modules.
• HS-MODE Supports HS-BURST with all HSGears HS-G1, HS-G2, HS-G3.
• HS-MODE Supports both data rate Series A and  SeriesB.
• LS-MODE Supports both MODULE-I and MODULE-II
• LS-MODE MODULE-I supports PWM-signaling with all PWM-Gears PWM-G0, PWM-G1 up to PWM-G7
• LS-MODE MODULE-II supports NRZ-Signaling.
• Configurable number of lanes for each Sublink.
• Supports protocol interface i.e. RMMI Interface.
• Supports 8b 10b encoding in Tx and decoding in Rx.
• Supports bypassing of 8b 10b encoding and decoding.
• Supports callbacks in transmitter and receiver.
• Supports wide variety of Error Injections.
• Supports protocol monitor real time exhaustive checks.
• Supports assertion for protocol checks.
• Supports coverage of different state transition.
Deliverables
•  MIPI M-PHY TX/RX BFM/Agent
•  MIPI M-PHY Monitor and Score board
•  Test-Bench Configurations
•  Test Suite(in source code) :
- Basic and Directed Protocol Tests
- Random Tests
- Error Scenario Tests
- Compliance Tests
- Assertions & Coverage Tests
- User Tests
•  User Guide and Release Notes
datasheet 如下:
WWAGO_MIPI_M-PHY__VIP_Datasheet.pdf (327.68 KB , 下载次数: 76 )
发表于 2014-9-11 10:58:03 | 显示全部楼层
学习一下
GMT+8, 2025-11-7 05:19 , Processed in 0.019100 second(s), 4 queries , Gzip On, Redis On.
