查看: 2353|回复: 2
[求助] 求助:icc的lab中打开.mv出错
发表于 2014-2-26 10:10:24 | 显示全部楼层 |阅读模式
按照论坛上的方式在虚拟机上破解ICC以后,做lab的时候,在lab0_gui中启动,打开risc_chip.mw,但是一直无法选择Cells,如下图:
查看错误代码:
       The specified library does not exist so you cannot open it for write or
       read, Or it is read only so you cannot open it for write.  If the above
       mentioned  issue does not exist, you may consider the following reason:
       During opening library, consistency checks  between  main  library  and
       each  reference  libraries  are made, and if error messages occur, e.g.
       inconsistent length unit or precision, the library  cannot  be  opened.
       See MWLIBP-328.
但是我感觉都是按照默认的设置路径,我没有改动库,而且root身份也试过,仍然不行,请大神指教,我只是需要用GUI界面打开文件而已
但是在实验室的服务器中同样的方式又可以显示并打开:
发表于 2014-2-26 14:25:22 | 显示全部楼层
炮哥!在linux下解压就ok啦!
发表于 2014-4-14 15:25:46 | 显示全部楼层
学习一下
GMT+8, 2025-12-14 13:15 , Processed in 0.017001 second(s), 6 queries , Gzip On, Redis On.
