查看: 4913|回复: 19
[招聘] analog design engineer
发表于 2014-2-13 16:55:49 | 显示全部楼层 |阅读模式
Analog circuit designfor the required IPs, such as, OTP, OVP, ULVO, Charge pumper, Bandgap and/orLDO
2)
Design, simulate andvalidate/verify analog IPs with 6-sigma concept for robust design
3)
Working closely withTop level AMS designer for integrating the IPs
4)
Writing analog designstatement and completed report for Analog IPs
5)
To close cooperationis needed with the test product engineer during the creation process of thetest plan and validation plan. Supporting test product engineer in productvalidation and participate debugging
6)
Customer engagementfor specifications and customer support for specific problem related to IPs
Profiles:
1)
MSEE or BSEE with5 years experience in Analog circuit design
2)
Must have completeddesign experience for 2 of the listed blocks: OTP, OVP, ULVO, Charge pumper,Bandgap and LDO
3)
Fluent in ADE andsimulation tools, such as spectre, hspice etc.
4)
Experience with ESDdesign is a plus
5)
Good communicator inboth oral and written English
6)
Good team player with focus on results and time management
 楼主| 发表于 2014-11-19 18:43:46 | 显示全部楼层
Smart Analog  有没有,有没有~
发表于 2014-11-19 22:26:06 | 显示全部楼层
在北京么
 楼主| 发表于 2014-11-20 09:33:48 | 显示全部楼层
回复 3# uestc_cjh
   在上海呢~
发表于 2014-11-20 10:02:11 | 显示全部楼层
从3年增加到 5年
从设计过下面一项增加为设计过下面两项 。。
 楼主| 发表于 2014-11-20 10:14:59 | 显示全部楼层
回复 5# lpf025
   所以你在其它地方也有看到过这个JD对么?...
 楼主| 发表于 2014-11-28 17:27:55 | 显示全部楼层
UP,Up~~ 这个职位目前不要求一定是做Battery Charge 只要是做Power DCDC,然后英文交流OK ,都可以尝试~~ 小伙伴们,快快来~
发表于 2014-12-1 13:39:51 | 显示全部楼层
NXP..........
 楼主| 发表于 2014-12-8 11:29:38 | 显示全部楼层
 楼主| 发表于 2014-12-18 10:05:11 | 显示全部楼层
年后还会有更多相关的职位,有需求的小伙伴,现在请联系起来,谢谢!
GMT+8, 2025-12-27 14:42 , Processed in 0.024243 second(s), 7 queries , Gzip On, Redis On.
