查看: 1671|回复: 0
[招聘] Cadence SH 招聘Principle Product Engineer(数字后端产品工程)
发表于 2014-2-8 10:55:21 | 显示全部楼层 |阅读模式
更多职位信息敬请关注Cadence公众微信平台:Cadence中国招聘
If you have interest, PLS send your update CV to zhangyl@cadence.com
Position Description:
1.Work in shanghai Engagement PE team, mainly focus on TSMC-related project.
20nm and 16nm FinFET flow establishment, from synthesis to final SI timing closure
2.Work closely with other team members for technique communication and projects.
3.Can take lead role in project plan and action.
4.Co-work closely with R&D team to find the debug the software problem in a IC backend way as early as possible.
Position Requirements:
1. Master with 7-8 years working experience or Bachelor with about 10years experience.
IC design background, especially in the back-end flow. Low Power related working experience will be a strong plus.
2. Syntheis, Backend experience, LVS, DRC, CLP knowledge and tape-out experience.
Unix System knowledge, vi/TCL/TK/CSH will be plus.
3. Strong scripting capability, including shell/tcl/perl.
4. Good communication in English and Chinese, good confidence and good self-motivation.
5. Good team spirit, well-aligned with the "One Cadence, One Team."
GMT+8, 2025-12-25 03:02 , Processed in 0.027696 second(s), 9 queries , Gzip On, Redis On.
