楼主: lizy369
[求助] 谁能帮忙回答下ADC方面的几个基本概念?
发表于 2020-3-4 17:37:58 | 显示全部楼层
lizy369 发表于 2014-1-22 11:21
回复 9# sxzong_hit
您好,新手入门,想请问下您,DR的概念怎么理解呢?
我看到 描述
Dynamic RangeTypically expressed in dB, dynamic range is defined as the range between the noise floor of a device and its specified maximum output level. An ADC's dynamic range is the range of signal amplitudes which the ADC can resolve; an ADC with a dynamic range of 60dB can resolve signal amplitudes from x to 1000x. Dynamic range is important in communication applications, where signal strengths vary dramatically. If the signal is too large, it over-ranges the ADC input. If the signal is too small, it gets lost in the converter's quantization noise
但是没有公式之类的,有时有点不太直观?
DR是最大的SNR吗?
谢谢
发表于 2020-5-13 11:13:16 | 显示全部楼层
afujian 发表于 2014-1-20 11:23
有效位和分辨率是一回事?SNR是指的输出的动态范围,DR是值得使得snr=0到最大SNR的输入范围! ...
“DR是值得使得snr=0到最大SNR的输入范围!”
是SNR还是SNDR啊?这里不用考虑谐波的影响么?
发表于 2020-5-13 11:14:16 | 显示全部楼层
sxzong_hit 发表于 2014-1-22 11:15
http://www.maximintegrated.com/app-notes/index.mvp/id/641
基本概念
这里边的DR只有定义,那怎么仿真呢?
GMT+8, 2025-12-24 18:51 , Processed in 0.012581 second(s), 3 queries , Gzip On, Redis On.
