查看: 5997|回复: 6
ADS 2013.06 和 ADS 2012.08 区别
发表于 2014-1-14 15:53:14 | 显示全部楼层 |阅读模式
ADS 2013.06 RELEASE HIGHLIGHTS
This release, ADS 2013.06, has new capabilities specifically intended for High-Speed Digital applications. Please review the new capabilities and the fixed defects carefully before upgrading. If you are working on RF or microwave designs we recommend that you continue to use ADS 2012.08.
Retimer Solution in Channel Simulation
An economical solution to quickly and accurately solve the challenge posed by signal distortion in the multigigabit-per-second regime
Now able to model mid-channel repeaters that have a clock/data recovery circuit (“re-timers”) using a pre-standard extension to the IBIS AMI specification
Enhancements aimed at power integrity circuit simulations
Support for power integrity keywords in the IBIS specification
Support for per-port reference impedance and mixed-mode s-parameters using the Touchstone 2.0 file format
New Design Tool: Touchstone Combiner
New tool builds multi-port victim/aggressor channel models from, for example, multiple S4P files typically obtained from a VNA measurement of PCB and package traces。
ADS 2012 delivers exciting new features for new and existing ADS users, including:
New Technologies and Breakthroughs for RF Power Amplifier Design
New multi-chip module FEM simulation analyzes interactions between ICs and interconnects in typical multichip modules
Offers a complete solution for the new Agilent NeuroFET model which enables more accurate FET modeling and simulation results
New electro-thermal simulator that incorporates dynamic temperature effects to improve accuracy
New Usability Improvements
New docking windows enable users to quickly access frequently used dialog boxes
New component search and net navigator functions make it easy to work with larger designs
New archive/un-archive utility makes sharing designs and workspaces easier
Increased Level of Integration with EMPro
EMPro 2012 includes a new level of integration with ADS 2012 that enables 3D EM components to be saved as database cells for use directly in ADS
New products for High Speed Digital Design
New product W2324 High Capacity Pre-processor supports selection of critical nets for EM modeling
New re-driver component in Channel Simulator based on a pre-standard extension to IBIS AMI
Simulation manager supports the new W2312 Transient Convolution Distributed Computer 8-pack
For a complete list of all the new capabilities and key features in ADS 2012 please refer to the ADS 2012 release notes: http://www.agilent.com/find/eesof-ads2012
IMPORTANT LICENSING UPDATE
发表于 2014-3-22 17:27:52 | 显示全部楼层
yuan lai ru ci
发表于 2014-8-21 12:41:27 | 显示全部楼层
外文不懂啊
发表于 2014-9-10 16:44:12 | 显示全部楼层
英文乍不懂
发表于 2014-11-13 20:32:03 | 显示全部楼层
这句红色的:如果你从事射频或微波设计我们建议您继续用2012版本的ADS。
其他没看
发表于 2015-11-29 15:47:32 | 显示全部楼层
谢谢啦啦啦啦啦啦
发表于 2019-8-12 16:32:38 | 显示全部楼层
thanks a lot
GMT+8, 2025-12-28 23:55 , Processed in 0.019280 second(s), 6 queries , Gzip On, Redis On.
