查看: 5347|回复: 12
[求助] 4*8段式LCD用stc12c5a60s2驱动,显示很暗,求解答谢谢
发表于 2014-1-13 16:24:25 | 显示全部楼层 |阅读模式
#include<c:\Keil\C51\INC\STC\STC12c5a60S2.H>
#define uchar unsigned char
#define uint unsigned int
sbit COM3=P2^3;
sbit COM2=P2^2;
sbit COM1=P2^1;
sbit COM0=P2^0;
sbit key1=P2^7;
uchar i;
unsigned char ScanCoun=0;
unsigned char C0[10]={0x01,0x00,0x01,0x01,0x00,0x01,0x01,0x01,0x01,0x01};
unsigned char C1[10]={0x03,0x02,0x02,0x02,0x03,0x01,0x01,0x02,0x03,0x03};
unsigned char C2[10]={0x01,0x00,0x03,0x02,0x02,0x02,0x03,0x00,0x03,0x02};
unsigned char C3[10]={0x03,0x02,0x01,0x03,0x02,0x03,0x03,0x02,0x03,0x03};
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
  for(y=110;y>0;y--);
key()                   // 按键函数
if(key1==0)
delay(10);
if(key1==0)
i++;
if(i>9)
i=0;
while(key1==0);
void  main(void)
   TMOD = 0x01;
   ET0 = 1;
   EA = 1;
   TR0 = 1;
   EA=1; //开全局总中断
   while(1)
void Timer0() interrupt 1     //定时器中断
     TL0=0x78; //&para;¨&Ecirc;±5ms
    TH0=0xec;
   P2M1 =0x0f;
    P2M0 =0x00;
    key();
     switch(ScanCoun)   //动态扫描
    case 0:                //COM3正向驱动
   COM0=1;
  COM1=1;
  COM2=1;
  COM3=0;
   P0=C0;
  P2M1 =0x07;
  P2M0 =0x00;
   break;
  case 1 :               //COM3反向驱动
  COM0=0;
  COM1=0;
   COM2=0;
   COM3=1;
  P0=~C0;
  P2M1 =0x07;
  P2M0 =0x00;
  break;
   case 2:              //COM2正向驱动
   COM0=1;
   COM1=1;
   COM2=0;
   COM3=1;
  P0=C1;
  P2M1 =0x0b;
  P2M0 =0x00;
  break;
   case 3:                //COM2反向驱动
  COM0=0;
  COM1=0;
  COM2=1;
  COM3=0;
   P0=~C1;
  P2M1 =0x0b;
   P2M0 =0x00;
   break;
    case 4:               //COM1正向驱动
  COM0=1;
  COM1=0;
  COM2=1;
  COM3=1;
   P0=C2;
  P2M1 =0x0d;
   P2M0 =0x00;
   break;
   case 5:               //COM1反向驱动
  COM0=0;
  COM1=1;
  COM2=0;
  COM3=0;
   P0=~C2;
  P2M1 =0x0d;
   P2M0 =0x00;
   break;
   case 6 :             //COM0正向驱动
  COM0=0;
  COM1=1;
  COM2=1;
  COM3=1;
   P0=C3;
  P2M1 =0x0e;
   P2M0 =0x00;
   break;
    case 7:              //COM0反向驱动
  COM0=1;
  COM1=0;
  COM2=0;
  COM3=0;
   P0=~C3;
  P2M1 =0x0e;
   P2M0 =0x00;
   break;
      ScanCoun++;       //加一
     if (ScanCoun>7) ScanCoun=0;
发表于 2014-1-14 22:02:51 | 显示全部楼层
若是实物的话,那是液晶硬件的问题,应该有个专门调节亮度的pin脚的,。仿真的话,不太了解
 楼主| 发表于 2014-1-15 09:01:48 | 显示全部楼层
回复 2# lcgolh
    哦,谢谢哈,我这个没有那个引脚,是用偏压做的
发表于 2014-1-15 13:58:03 | 显示全部楼层
感觉不像是代码的问题......
 楼主| 发表于 2014-1-15 15:24:11 | 显示全部楼层
回复 4# guolehaohao
    硬件有问题?这个图是stc数据手册给的。
发表于 2014-1-15 17:27:48 | 显示全部楼层
驱动LCD,使用了3个状态
1、高电平
2、低电平
3、高阻,因为外部分压电阻,实际是1/2 VDD
 楼主| 发表于 2014-1-15 17:43:28 | 显示全部楼层
回复 6# McuPlayer2013
    嗯,是啊,我想写写1/3偏压,试试能不能把对比度调节的好些
发表于 2014-1-16 16:20:20 | 显示全部楼层
自己搭电路,驱动1/3bias太复杂了,你还不如用driver芯片,比如HT1621之类
发表于 2014-1-16 16:21:02 | 显示全部楼层
另外,也要注意LCD防极化的处理,信号要周期性的反向
 楼主| 发表于 2014-1-17 08:58:43 | 显示全部楼层
回复 8# McuPlayer2013
    不是想锻炼下自己写程序嘛,而来可以节约成本的。
GMT+8, 2025-12-16 02:41 , Processed in 0.023984 second(s), 6 queries , Gzip On, Redis On.
