查看: 11487|回复: 18
[求助] 求助关于PLL带宽的问题
发表于 2014-1-7 09:41:36 | 显示全部楼层 |阅读模式
假设PLL的闭环带宽是1MHz ,输入信号是100MHz的正弦波,那么输出还是100MHz的正弦波
并没有被环路的带宽所衰减,哪位高手能解释一下,这是为什么呢???
发表于 2014-1-7 09:59:48 | 显示全部楼层
the measurement seems not correct.
what is your reference frequency ?
if you want to know the pll bandwidth by input frequency sweeping, please use a frequency modulated reference frequency, such as sweeping, fref + 1kHz, fref + 10KHz ,fref + 100KHz, ... freq + 10MHz, then at the pll output you record the amplitude of the spurs of the carrier with the offset frequency of 1kHz ,10Khz, ...the shape should follow your close loop transfer function.
 楼主| 发表于 2014-1-7 10:39:36 | 显示全部楼层
回复 2# wfcawy
谢谢您的回复,我好像理解一些了,PLL的带宽是指输入信号变化的程度吧,若输入信号的频率没有改变
或者变化在1MHz以内那么输出信号就与输入信号是一样的,输出信号都能跟随输入的变化,
若输入信号的频率变化超过1MHz,那么输出就会对输入产生衰减也就是说输出跟不上输入信号了。
发表于 2014-1-7 11:51:30 | 显示全部楼层
pll 带宽针对的变量是相移(频率变化),而不是电压
发表于 2014-1-7 14:35:13 | 显示全部楼层
回复 3# lynn13579
   输入100Mhz?你的参考频率是多少,分频比是多少?
PLL 的小信号模型是用来分析相位误差的。
发表于 2014-1-7 15:41:46 | 显示全部楼层
回复 3# lynn13579
    pll的带宽是针对小信号相位变化而言,这里100MHz是一个稳定的输入频率,应该相当于放大器的dc工作点吧
发表于 2014-1-7 17:57:51 | 显示全部楼层
回复 3# lynn13579
suppose the bandwidth of PLL is 1MHz, and the reference frequency is not clean (contain other low frequency contents).
the low frequency contents will appear at  PLL out as spur, and if no divider is in the loop, the locations of the spurs are the same frequency as the low frequency contents
if the frequency contents smaller than 1Mhz, it will not be suppressed by the pll loop,
however , if the frequency contents larger than 1MHz, it will suppressed somehow by the pll loop regarding to the PLL orders.
so , in total, if you sweep the low frequency contents, the shape after combination of the spurs will follow the pll  close loop transfer function(phi_out(s)/phi_in (s))
发表于 2014-1-8 01:00:22 | 显示全部楼层
   Mark。Slides上字咋那么眼熟。。。很像一个熟人的字,但好像他过去一直是做器件模型的。
发表于 2014-1-8 08:18:49 | 显示全部楼层
环路处理的是phase而非频率
 楼主| 发表于 2014-1-8 19:23:59 | 显示全部楼层
回复 7# wfcawy
    理解了,非常感谢!!!
GMT+8, 2025-11-22 00:27 , Processed in 0.023232 second(s), 7 queries , Gzip On, Redis On.
