楼主: baluba
Syn0p$y$ RSoft Component suite 2013.12
头像被屏蔽
发表于 2014-5-4 09:43:15 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2014-5-8 18:18:26 | 显示全部楼层
回复 51# 592014
    hello . i installed and cracked Rsoft v9 (win version)
    but its crack did not worke correctly.
    for example : in the non-linear  photonic crystal did not work its Kerr Effect but Kerr Effect worked correctly on rsoft v8 and v5
     Kerr Effect didnot worked in this version with this crack (v9).
     Kerr Effect is  very important for designing the non-linear photonic devices.
     can you helpe me ??
头像被屏蔽
发表于 2014-5-8 21:07:30 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2014-5-8 22:08:05 | 显示全部楼层
回复 53# 592014
    tank you for you reply.
    because rsoft didnot have any responses
    i considered power=1000 and Kerr Effect=10
    this values are very illogical.
    even there was not any answer with this values
test.rar
2.77 KB, 下载次数: 14 , 下载积分: 资产 -2 信元, 下载支出 2 信元
.ind file for testing about non-linearity in Rsoft v9
发表于 2014-5-9 08:42:19 | 显示全部楼层
回复 54# mahemorad
你的破解不完全把,没见过rsoft用这种破解方式只需要破解cad一个文件的,应该各个组件都有对应的,也许是其他组件没有破解,无法启动,导致结果不对吧
发表于 2014-5-10 06:38:14 | 显示全部楼层
回复 55# zq00001
    i cracked correctly. loaded other simulators. fullwave worked correctly but didnot work only kerr effect in full wave .
头像被屏蔽
发表于 2014-5-10 09:17:18 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2014-5-10 13:47:07 | 显示全部楼层
回复 57# 592014
    I can not describe all of non-linear optic for you. you reffer the nonlinear photonic crystal design in photonic papers.
     but i upload a test file for you. you should click the run bottom of full wave dialog bax.
    in result windows in fullwave simulation, you see a red curve that becoms zero . this red curve shoud not becom zero.
    it should be becom  about 0.8 or near 1 values.
    this result ( becom 0.8 for red curve ) in rsoft 8,5,7 ( 3 versions of rsoft) have been happend.
发表于 2014-5-12 13:39:21 | 显示全部楼层
Perfect,,many thanks for sharing your files.
How can I appreciate for that?
GOD bless you.
发表于 2014-6-1 11:20:34 | 显示全部楼层
can you upload linux version?
GMT+8, 2025-12-24 21:16 , Processed in 0.022568 second(s), 5 queries , Gzip On, Redis On.
