用modelsim做时序反标的时候,出现如下错误:# ** Error: (vsim-SDF-3262) i2c_reader.sdf(1221): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) i2c_reader.sdf(1222): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) i2c_reader.sdf(1223): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) i2c_reader.sdf(1224): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) i2c_reader.sdf(1225): Failed to find matching specify timing constraint.
# ** Error: (vsim-SDF-3262) i2c_reader.sdf(1226): Failed to find matching specify timing constraint.
对应sdf文件的相应行是这样的:
(SETUP (COND ENABLE_RB===1'b1 (posedge D)) (COND ENABLE_RB===1'b1 (posedge CK)) (0.1841:0.1841:0.1841))
(SETUP (COND ENABLE_RB===1'b1 (negedge D)) (COND ENABLE_RB===1'b1 (posedge CK)) (0.1965:0.1965:0.1965))
(HOLD (COND ENABLE_RB===1'b1 (posedge D)) (COND ENABLE_RB===1'b1 (posedge CK)) (0:0:0))
(HOLD (COND ENABLE_RB===1'b1 (negedge D)) (COND ENABLE_RB===1'b1 (posedge CK)) (0:0:0))
(WIDTH (COND ENABLE_RB===1'b1 (posedge CK)) (0.4649:0.4649:0.4649))
(WIDTH (COND ENABLE_RB===1'b1 (negedge CK)) (0.3136:0.3136:0.3136))
还有一类错误是:
# ** Error: (vsim-SDF-3261) i2c_reader.sdf(1234): Failed to find matching specify module path.
# ** Error: (vsim-SDF-3261) i2c_reader.sdf(1235): Failed to find matching specify module path.
# ** Error: (vsim-SDF-3261) i2c_reader.sdf(1236): Failed to find matching specify module path.
# ** Error: (vsim-SDF-3261) i2c_reader.sdf(1237): Failed to find matching specify module path.
# ** Error: (vsim-SDF-3261) i2c_reader.sdf(1238): Failed to find matching specify module path.
# ** Error: (vsim-SDF-3261) i2c_reader.sdf(1239): Failed to find matching specify module path.
# ** Error: (vsim-SDF-3261) i2c_reader.sdf(1240): Failed to find matching specify module path.
# ** Error: (vsim-SDF-3261) i2c_reader.sdf(1241): Failed to find matching specify module path.
对应的sdf文件为:
(COND CK===1'b1&&D===1'b1 (IOPATH RB Q () (0.4799:0.4799:0.4799)))
(COND CK===1'b1&&D===1'b0 (IOPATH RB Q () (0.4797:0.4797:0.4797)))
(COND CK===1'b0&&D===1'b1 (IOPATH RB Q () (0.4695:0.4695:0.4695)))
(COND CK===1'b0&&D===1'b0 (IOPATH RB Q () (0.4787:0.4787:0.4787)))
(COND CK===1'b1&&D===1'b1 (IOPATH RB QB (0.4626:0.4626:0.4626) ()))
(COND CK===1'b1&&D===1'b0 (IOPATH RB QB (0.4685:0.4685:0.4685) ()))
(COND CK===1'b0&&D===1'b1 (IOPATH RB QB (0.582:0.582:0.582) ()))
(COND CK===1'b0&&D===1'b0 (IOPATH RB QB (0.5897:0.5897:0.5897) ()))
请教上面两类错误怎么解决?sdf文件是Design Compiler导出来的。 |
