查看: 5640|回复: 9
[讨论] link to download cadence ic
发表于 2013-12-23 22:55:43 | 显示全部楼层 |阅读模式
hello sir
can you give me link to download cadence ic  please?
i want the CDRom copy of IC615,because i have download many version d'ont working
发表于 2013-12-24 00:59:59 | 显示全部楼层
回复 1# french_designer
hello
    i help you to install cadence
please say to me what is your problem?
 楼主| 发表于 2013-12-24 01:40:17 | 显示全部楼层
回复 2# mabas.masood
my problem is the installscape
when I use the archive I downloaded from the website eetop installscape does not recognize, except that an archive of IC610 in the form CDROM1 to 7
the others like SOC encouter archive
in the folder that contain the installation files SOC enconter I found:
dosier KITS
Redeme
IC_index.sdx
发表于 2013-12-24 02:24:51 | 显示全部楼层
回复 3# french_designer
if you dont have iscape you could download from this link
http://bbs.eetop.cn/viewthread.php?tid=370361&highlight=iscape
after that you must extract in separate folder and run
please tell me what is you linux version and architecture (32bit or 64bit)?
 楼主| 发表于 2013-12-24 08:39:53 | 显示全部楼层
i use  ubuntu 13 32 bit  and fedora 12 64 bit
this message when i install SOC encounter
Errors during installation.
    Detailed error information is in the following file:
    /home/omar/.iscape/iscape_logs/20131224_013543_run.txt
The following selected products were NOT installed:
    3001:Virtuoso Digital Implementation Option
    3002:Virtuoso Digital Implementation
    EDS100:Encounter Digital Implementation System L
    EDS200:Encounter Digital Implementation System XL
    FE100GPS:First Encounter - XL (aka Cadence (R) First Encounter - GPS)
    FE100:Cadence(R) First Encounter Ultra
    FE150:Cadence(R) NanoRoute Ultra SoC Routing Solution
    FE200GPS:SOC Encounter - XL (aka Cadence (R) SOC Encounter - GPS)
    FE200:Cadence(R) SoC Encounter
    FE300DBS:SoC Encounter - L (aka Nano Encounter Demand Based Savings)
    FE300:Nano Encounter
    FE800:First Encounter - GXL
    FE80:First Encounter - L (aka First Encounter VIP)
    FE850:SoC Encounter - GXL
    FE851:SoC Encounter - GXL
发表于 2017-12-6 18:43:39 | 显示全部楼层
helpok
发表于 2018-10-13 23:13:02 | 显示全部楼层
发表于 2018-10-13 23:55:01 | 显示全部楼层
It seems good
发表于 2018-10-13 23:55:43 | 显示全部楼层
thank you
发表于 2018-10-14 00:00:43 | 显示全部楼层
Who is the landlord everyone is refering to
GMT+8, 2025-12-22 23:12 , Processed in 0.022429 second(s), 5 queries , Gzip On, Redis On.
