查看: 2979|回复: 9
SOC encoder installation problem
发表于 2013-12-12 14:00:16 | 显示全部楼层 |阅读模式
I have this problem when I try install SOC.
any file not found in my SOC files to install it.
1
1
2
2
发表于 2013-12-12 18:35:00 | 显示全部楼层
回复 1# mooh2028
rename IS*.z to IS*.t.z
 楼主| 发表于 2013-12-13 08:24:14 | 显示全部楼层
the same issue
7
7
发表于 2013-12-13 13:51:26 | 显示全部楼层
楼主我服你了了。。。
 楼主| 发表于 2013-12-14 07:37:52 | 显示全部楼层
i can't understand what u say
发表于 2013-12-14 14:42:17 | 显示全部楼层
回复 3# mooh2028
please repeat these steps
1- install ncompress
for this you can download from pkgs.org and install with doubleclick
2- copy IS*.Z to special folder like /home/Desktop/A
3 open terminal
     cd /root/Desktop/A
     ncompress ISCAP03.Z
   (you must convert .TZ to Z)
4 you must have ISCAP03.t in folder A after that
5 in the terminal
        tar -xf ISCAP03.t
6 you must have two folders data and iscape
7 you run this in terminal
       /root/Desktop/A/iscape/bin/iscape.sh'
8 after that you need install from ISCAPE GUI
i send you several pics for these step
 楼主| 发表于 2013-12-17 01:23:07 | 显示全部楼层
i face that
q
q
发表于 2013-12-17 13:10:20 | 显示全部楼层
回复 7# mooh2028
    run this in terminal (in root)
apt-get install ncompress
i recommend you install centos 6 for cadence software i think you use ubuntu
发表于 2014-5-21 22:28:18 | 显示全部楼层
多谢分享
发表于 2014-5-21 22:39:42 | 显示全部楼层
多谢分享
GMT+8, 2025-12-25 06:54 , Processed in 0.024359 second(s), 6 queries , Gzip On, Redis On.
