查看: 3324|回复: 3
[求助] 51汇编与C全面周立功
发表于 2013-12-10 14:32:39 | 显示全部楼层 |阅读模式
书上系统时钟例程能看懂,但后面对该例程的优化看不明白了。怎么将下面这段代码与时钟系统的c程序连接起来呢?我试了好长时间,一直没成功。
CSEG AT 0400H
bcdmap: DB '0' ,'0'
DB '0' ,'1'
DB '0' ,'2'
DB '5' ,'7'
DB '5' ,'8'
DB '5' ,'9'
END
 楼主| 发表于 2013-12-11 15:46:52 | 显示全部楼层
原程序中是这样初始化二维数组的。但这样的数组无法定位表头的地址,地址由keil自动编译产生。
uchar code bcdmap[60][2]={
"00", "01","02", "03","04", "05","06", "07","08", "09","10", "11","12", "13","14",
"15","16", "17","18", "19","20", "21","22", "23","24", "25","26", "27","28", "29",
"30", "31","32", "33","34", "35","36", "37","38", "39","40", "41","42", "43","44",
"45","46", "47","48", "49","50", "51","52", "53","54", "55","56", "57","58", "59"};
下面这段汇编代码就能把表头地址定位在ROM区的0400H位置上,缩短主程序查询表格的指令周期。就是用这段汇编代码取代原程序中的C语言定义的方法。 但是不知道怎么把这小段汇编代码与C程序连接起来。
 楼主| 发表于 2013-12-11 15:48:54 | 显示全部楼层
自己写的a51文件,用下面这段代码能与C程序连接上吗? 编译后提示 *** WARNING L9: EMPTY SEGMENTS ENCOUNTERED
NAME    ?C_STARTUP
?C_C51STARTUP   SEGMENT   CODE
?STACK          SEGMENT   IDATA
                  RSEG    ?STACK
                  DS      1
                  EXTRN CODE (?C_START)
                  PUBLIC  ?C_STARTUP
                  CSEG    AT      0
?C_STARTUP:
      CSEG    AT      0400H
bcdmap:
DB  '0' ,'0'
DB  '0' ,'1'
DB  '5' ,'9'
LJMP    ?C_START
                  END
发表于 2015-11-23 22:03:41 | 显示全部楼层
51汇编与C全面周立功
GMT+8, 2025-9-18 08:37 , Processed in 0.017112 second(s), 6 queries , Gzip On, Redis On.
