查看: 12853|回复: 49
[资料] 论坛首发2013 Springer新书: Voltage-to-Frequency Converters: CMOS Design...
发表于 2013-12-5 16:15:57 | 显示全部楼层 |阅读模式
Voltage-to-Frequency Converters: CMOS Design and Implementation (Analog Circuits and Signal Processing) [Hardcover]  Cristina Azcona Murillo           (Author), Belén Calvo Lopez (Author), Santiago Celma (Author)
          Be the first to review this item
http://www.amazon.com/Voltage---Frequency-Converters-Implementation-Processing/dp/1461462363/ref=sr_1_1?ie=UTF8&qid=1386230622&sr=8-1&keywords=Voltage-to-Frequency+Converters%3A+CMOS+Design+and+Implementation
   Book DescriptionPublication Date: March 21, 2013  | ISBN-10: 1461462363   | ISBN-13: 978-1461462361  | Edition: 2013
                     This book develops voltage-to-frequency converter (VFC) solutions integrated in standard CMOS technology to be used as a part of a microcontroller-based, multisensor interface in the environment of portable applications, particularly within a WSN node.  Coverage includes the total design flow of monolithic VFCs, according to the target application, as well as the analysis, design and implementation of the main VFC blocks, revealing the main challenges and solutions encountered during the design of such high performance cells. Four complete VFCs, each temperature compensated, are fully designed and evaluated: a programmable VFC that includes an offset frequency and a sleep/mode enable terminal; a low power rail-to-rail VFC; and two rail-to-rail differential VFCs.
Editorial Reviews           From the Back Cover              This book develops voltage-to-frequency converter (VFC) solutions integrated in standard CMOS technology to be used as a part of a microcontroller-based, multisensor interface in the environment of portable applications, particularly within a WSN node.  Coverage includes the total design flow of monolithic VFCs, according to the target application, as well as the analysis, design and implementation of the main VFC blocks, revealing the main challenges and solutions encountered during the design of such high performance cells. Four complete VFCs, each temperature compensated, are fully designed and evaluated: a programmable VFC that includes an offset frequency and a sleep/mode enable terminal; a low power rail-to-rail VFC; and two rail-to-rail differential VFCs.
      Product Details
  • Series: Analog Circuits and Signal Processing
  • Hardcover: 192 pages
  • Publisher: Springer; 2013 edition (March 21, 2013)
  • Language: English
  • ISBN-10: 1461462363
  • ISBN-13: 978-1461462361
Voltage-to-Frequency Converters CMOS Design and Implementation.pdf (3.38 MB , 下载次数: 781 )
发表于 2013-12-5 16:35:29 | 显示全部楼层
nicer
发表于 2013-12-5 20:27:32 | 显示全部楼层
赞楼主,这是一个值得下载的好资料。
发表于 2013-12-6 07:03:10 | 显示全部楼层
正好需要~~!!支持支持,非常感谢
发表于 2013-12-6 08:28:08 | 显示全部楼层
感觉确实是一本不错的书,多谢楼主
发表于 2013-12-6 10:46:46 | 显示全部楼层
很有用的技术,值得好好看看!
发表于 2013-12-6 15:49:52 | 显示全部楼层
xia le  kankan  ..
发表于 2013-12-6 16:18:42 | 显示全部楼层
回复 1# haoyun
感謝分享
发表于 2013-12-6 17:52:51 | 显示全部楼层
好像有了
发表于 2013-12-6 19:43:25 | 显示全部楼层
感觉书名好屌啊!!
GMT+8, 2025-12-21 22:37 , Processed in 0.031412 second(s), 7 queries , Gzip On, Redis On.
