查看: 1861|回复: 0
[招聘] Cadence SH 招聘 Principle SiP/SI/PI Engineer
发表于 2013-12-4 16:48:27 | 显示全部楼层 |阅读模式
Cadence SH 招聘 Principle SiP/SI/PIEngineer
更多职位信息敬请关注Cadence公众微信平台:Cadence_Recruitment
Ifyou have interest, PLS send your update CV to job_china@cadence.com
Position Description:
Completepower-delivery system analyses across chips, packages and boards. System-levelSI analysis, including simultaneous switching noise analysis of high-speedsignal transmissions, and advances physical design for single- and multi-chippackages, states-of-the-art 3D packages, and systems in packaged (SiP). Theengineer should be able to act as a strong team member and contributor.
Specificduties include:
- Be responsible for building SI/PI/SiP design flow forHigh-speed IP Design
- Proficiency inCadence tools: Allegro and Sigrity
Proficiency in Hspice or spectre simulation, especiallyin high-speed simulation.
Good knowledge in modeling, for example IBIS.
Good knowledge in high-speed PCB design.
* At least eight years experience focus on SiP and SI/PIanalysis, excellent communication skills and the uncanny ability to both leadand contribute in a cooperative team environment is required.
Positionrequirements:
Essential Qualifications:
1.Must have BS degreewith 10+ years of applicable experience, MS degree with 7+years of applicable experience
in electricalengineering, microelectronics, comparable engineering science or solid statephysics.
2.Essential that theindividual demonstrates strong communication, verbal and written. Requires goodcommunication skills in English.
DesirableQualifications:
Aminimum of seven years relevant experience in industry.
-At least five years experience driving SiP/PI/SI project.
-Will have demonstrated successful completion of 10+ projects as an individualcontributor
GMT+8, 2025-11-10 03:31 , Processed in 0.015711 second(s), 6 queries , Gzip On, Redis On.
