查看: 3403|回复: 2
[求助] ocean script 求助
发表于 2013-11-29 13:52:39 | 显示全部楼层 |阅读模式
ocnWaveformTool( 'wavescan )
simulator( 'aps )
design(  "./netlist")
CorTempList=list(
list("top_tt",85,0.9,1.8)
list("top_ss",-40,0.81,1.62)
list("top_ff",125,0.99,1.98)
I=0
p=outfile("./delay.txt" "w")
fprintf(p,"%s \n" "corner td_en td_pd td_pu td_ensd td_en" )
foreach(CorTemp CorTempList
  tsmc=nth(0,CorTemp)
  Temp=nth(1,CorTemp)
  pwr1=nth(2,CorTemp)
  pwr2=nth(3,CorTemp)
  I=I+1
  resultsDir(strcat("./") tsmc)
  modelFile(
    list("/ip/lvdt01a/lvdt01aa/28PDK/tsmcN28/../models/spectre/toplevel.scs" tsmc)
  analysis('tran ?stop "120n"  ?errpreset "moderate"  )
  desVar(   "xod" 25m     )
  desVar(   "tr" 10p      )
  desVar(   "xfreq" 1.1e9 )
  desVar(   "xcm" 0.9     )
  desVar(   "xavdd" pwr2  )
  desVar(   "xdvdd" pwr1  )
  envOption(
        'analysisOrder  list("dc" "tran" "ac")
  temp(Temp)
  saveOption( 'save "selected" )
  save( 'v "/PD" "/EN" "/EN_SD" "/sdc<0>" "/sda<23>" "/da<23>" "/clk<0>" )
  run()
  selectResult( 'tran )
  td_en = value( delay(VT("/EN") pwr1/2 1 "rising" VT("/clk<0>") pwr1/2 1 "rising" 1 1 t ) )
  td_pd = value( delay(VT("/PD")  pwr1/2 1 "rising" VT("/clk<0>")  pwr1/2 1 "falling" 1 1 t ) )
  td_pu = value( delay(VT("/PD")  pwr1/2 1 "falling" VT("/clk<0>")  pwr1/2 2 "rising" 1 1 t ) )
   td_ensd = value( delay(VT("/EN_SD")  pwr1/2 1 "rising" VT("/sdc<0>")  pwr1/2 1 "rising" 1 1 t ) )
  td_en = value( delay(VT("/EN")  pwr1/2 1 "falling" VT("/clk<0>")  pwr1/2 3 "falling" 1 1 t ) )
  fprintf(p,"%s %f %f %f %f %f \n" tsmc td_en td_pd td_pu td_ensd td_en)
  close(p)
  printf("\n---End---\n")
一直报错
求大神帮忙改改,不胜感激
The directory you specified does not contain valid PSF
          results. Please check the line for typographical errors or
          look in the directory for a logFile and PSF result files.
          You need to specify what results you want to look at before
          using this command. You can do this with the openResults()
          command. See ocnHelp('openResults) for more information.
*Error* fprintf/sprintf: format spec. incompatible with data - nil
*Error* load: error while loading file - "delay.ocn"
发表于 2013-11-29 15:19:18 | 显示全部楼层
都用tsmc28了,还不用ADEXL?
发表于 2014-1-7 13:20:03 | 显示全部楼层
就按照提示openResult()和路径输进去试试啊
GMT+8, 2025-12-26 21:33 , Processed in 0.021057 second(s), 6 queries , Gzip On, Redis On.
