查看: 26346|回复: 93
飞利浦的LPC2300和LPC2400系列代码集
发表于 2007-3-2 10:22:46 | 显示全部楼层 |阅读模式
飞利浦的LPC2300和LPC2400系列代码集,很全的。
The directory tree and content of the sample software
common
    -- inc
-- lpc23xx.h  Definition file of all the registers of LPC23xx
-- irq.h  Interrupt related definitions and API prototyping
-- type.h  Type definition
-- target.h  Target specific definition for Keil's MCB2300 board
-- timer.h  Definition and header file for timer module
    -- src
-- startup.s  Code start up entry
-- swi_handler.s SWI handler
    Note: not used, but a good example for future references.
-- irq.c  Generic SWI interrupt handler related APIs
-- target.c  Target specific modules
-- timer.c  Timer related APIs
GPIO
    -- fio.h   GPIO and fast I/O header
    -- fio.c   GPIO and fast I/O APIs
    -- fiotest.c  GPIO and Fast I/O test module
    -- fio.uv2   uVision project file
EXTINT
    -- extint.h   External interrupt header
    -- extint.c   External interrupt APIs
    -- einttest.c  External interrupt test module
    -- extint.uv2  uVision project file
Timer
    -- tmrtest.c  Timer test module, note: API modules
    are in the COMMON directory and
    shared and used by some other peripheral testing.
    -- timer.uv2  uVision project file
PWM
    -- pwmc.h   PWM header
    -- pwm.c   PWM APIs
    -- pwmtest.c  PWM test module
    -- pwm.uv2   uVision project file
SPI
    -- spi.h   SPI header
    -- spi.c   SPI APIs
    -- spitest.c  SPI test module
    -- spi.uv2   uVision project file
SSP
    -- ssp.h   SSP(SPI1) header
    -- ssp.c   SSP(SPI1) APIs, for DMA and non-DMA
    -- ssptest.c  SSP(SPI1) test module
    -- ssp.uv2   uVision project file
UART
    -- uart.h   UART header
    -- uart.c   UART APIs
    -- uarttest.c  UART test module
    -- uart.uv2   uVision project file
RTC
    -- rtc.h   Real-time clock(RTC) header
    -- rtc.c   Real-time clock(RTC) APIs
    -- rtctest.c  Real-time clock(RTC) test module
    -- rtc.uv2   uVision project file
MCI
    -- mci.h   MCI header
    -- mci.c   MCI APIs for both SD and MMC card interface,
    for DMA and non-DMA.
    -- mcitest.c  MCI test module
    -- mci.uv2   uVision project file
ADC
    -- adc.h   ADC header
    -- adc.c   ADC APIs
    -- adctest.c  ADC controller test module
    -- adc.uv2   uVision project file
DAC
    -- dac.h   DAC header
    -- dac.c   DAC APIs
    -- dactest.c  DAC test module
    -- dac.uv2   uVision project file
I2C
    -- i2c.h   I2C header
    -- i2c.c   I2C APIs
    -- i2cmst.c   I2C test module
    -- i2cmst.uv2  uVision project file
I2S
    -- i2s.h   I2S header
    -- i2s.c   I2S APIs
    -- i2stest.c  I2S test module
    -- i2s.uv2   uVision project file
CAN
    -- can.h   CAN header
    -- can.c   CAN APIs
    -- cantest.c  CAN test module
    -- can.uv2   uVision project file
DMA
    -- dma.h   DMA header
    -- dma.c   GPDMA APIs, memory to memory,
    memory to peripheral or peripheral
    to memory are in SSP, MCI directory.
    -- dmatest.c  DMA test module
    -- dma.uv2   uVision project file
WDT
    -- wdt.h   Watchdog timer header
    -- wdt.c   Watchdog timer APIs
    -- wdttest.c  Watchdog timer test module
    -- wdt.uv2   uVision project file
PWRMAN
    -- pwrman.h   Power management header
    -- pwrman.c   Power management APIs
    -- pmtest.c   Power management test module,
    test powerdown and external interrupt wakeup.
    -- pwrman.uv2  uVision project file
PortLCD
    -- portlcd.h  4-bit port to LCD driver header for Keil MCB2300
    -- portlcd.c  4-bit port to LCD driver APIs
    -- lcdtest.c  4-bit port to LCD test module
    -- portlcd.uv2  uVision project file
EMAC
    -- crc32.h   CRC calculation header
    -- crc32.c   CRC calculation APIs
    -- emac.h   EMAC header
    -- emac.c   EMAC APIs, options include transmit only(TX_ONLY);
    receive packet, switch source and destination
    and transmit(BOUNCE_RX), WOL, etc.
    -- emactest.c  EMAC test module
    -- emac.uv2   uVision project file
    -- ethpkt.txt  Ethernet packet example for transmit
USBDEV
    -- hid.h   USB HID related header
    -- hiduser.h  USB HID user specific header
    -- hiduser.c  USB HID user APIs
    -- usb.h   USB header
    -- usbcfg.h   USB configuration header
    -- usbcore.h  USB Core header
    -- usbcore.c  USB Core APIs
    -- usbdesc.h  USB descriptor header
    -- usbdesc.c  USB descriptor APIs
    -- usbhw.h   USB hardware header
    -- usbhw.c   USB hardware APIs
    -- usbreg.h   USB misc. register header
    -- usbuser.h  USB user header
    -- useuser.c  USB user APIs
    -- usbmain.c  USB HID test module, power management, USB
    suspend to powerdown, and resume to USB
    wakeup.
    -- usbdev.uv2  uVision project file
USBAudio
    -- audio.h   USB Audio related header
    -- adcuser.h  USB Audio Device Class user specific header
    -- adcuser.c  USB Audio Device Class user APIs
    -- usb.h   USB header
    -- usbaudio.h  USB Audio misc. definition header
    -- usbmain.c  USB Audio test module
    -- usbaudio.uv2  uVision project file
NXP示例编码集.rar
556.48 KB, 下载次数: 1041 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-4-16 12:31:47 | 显示全部楼层
ggggggg
ggggggggggg
发表于 2007-4-23 19:36:31 | 显示全部楼层
very good
发表于 2007-4-23 21:58:31 | 显示全部楼层
谢谢分享
发表于 2007-5-12 10:15:21 | 显示全部楼层
好东西,大家分享
好东西,大家分享
发表于 2007-7-10 22:47:49 | 显示全部楼层
good
good good
发表于 2007-11-22 14:42:44 | 显示全部楼层
看得到,却下不了。为什么?
发表于 2007-12-6 13:16:30 | 显示全部楼层
fgfgfgffg
发表于 2007-12-7 10:25:44 | 显示全部楼层
kanbudao
发表于 2007-12-10 14:57:43 | 显示全部楼层
thanks
GMT+8, 2025-12-31 06:02 , Processed in 0.026100 second(s), 8 queries , Gzip On, Redis On.
