查看: 2801|回复: 5
[求助] SNDR in Current Steering DAC
发表于 2013-10-8 21:03:03 | 显示全部楼层 |阅读模式
Hi all ,
Resently I have simulated the SNDR of a 12b Current sterring DAC ,but it is only 54dB, thus the enob is 9bit . Simulation by Cadence without mc model.
So, I'm very confused why the DAC's SNDR was so bad ?
Can anyone give me some help?
By the way, How to tradoff the transistors' size of current source for the Statics and Dynamic performance ?
Best regards!
lvbq
发表于 2013-10-9 11:07:23 | 显示全部楼层
At first you should provide some circuit structure information and simulation results, so we can analysis the issue.
发表于 2013-10-9 11:09:35 | 显示全部楼层
How about the DNL/INL character of your DAC?
发表于 2013-10-9 16:38:36 | 显示全部楼层
没用校准的话,输出阻抗继续加大吧,没别的
电流管L做大点,开关管面积小点,静态的靠DEM,动态的靠开关交越点调整或者dummy开关什么的
 楼主| 发表于 2013-10-9 23:32:41 | 显示全部楼层
回复 4# kwankwaner
   OK,Thanks
 楼主| 发表于 2013-10-9 23:32:46 | 显示全部楼层
回复 4# kwankwaner
   OK,Thanks
GMT+8, 2025-12-28 10:26 , Processed in 0.081324 second(s), 6 queries , Gzip On, Redis On.
