Waveform
我写了一个test bench来测试一个4-bit 加法器。 加法器里有一个输出使能控制信号,该信号为低时可输出技术,否则输出Z。在test bench里已经对该使能信号做了控制,可是波形里始终是无效的。求大神帮忙啊!感激不尽!
testbench代码
- `timescale 1ns / 100ps
- module count16_tb ;
- reg oe_1 ;
- reg load_1 ;
- reg rst_1 ;
- reg clk ;
- reg [3:0] cnt_in ;
- reg enable_1 ;
- //Outputs from the Device Under Test are wire type
- wire [3:0] count ;
- wire [3:0] count_tri ;
- //Initial blocks are sequenctial and start at time 0
- initial
- begin
- $display($time,"<<Starting the simulation>>");
- clk=1'b0;
- rst_1=1'b0;
- load_1=1'b1;
- enable_1=1'b1;
- cnt_in=4'b0;
- oe_1=1'b0;
- #20 rst_1=1'b1;
- $display($time,"<<Coming out of reset>>");
- @(negedge clk);
- //load passed initial value to the counter.
- load_counter(4'hA);
- @(negedge clk);
- $display($time,"<<Turning ON the count enable>>");
- enable_1<=1'b0;
- wait(count==4'b0001);
- $display($time,"<<count=%d-Turning OFF the count enable>>",count);
- enable_1=1'b1;
- #40;
- $display($time,"<<Turning OFF the OE>>");
- oe_1=1'b1;
- #20;
- $display($time,"<<Simulation Complete>>");
- $stop;
- end
- //Instantiate the Device Under Test
- count16
- DUT (
- .oe_1 (oe_1 ) ,
- .load_1 (load_1 ) ,
- .rst_1 (rst_1 ) ,
- .count (count ) ,
- .clk (clk ) ,
- .cnt_in (cnt_in ) ,
- .enable_1 (enable_1 ) ,
- .count_tri (count_tri ) );
- //Create a 50Mhz clock.
- always
- #10 clk=~clk;
- //The load_count task loads the counter with the value passed.
- task load_counter;
- input [3:0] load_value;
- begin
- @(negedge clk);
- load_1<=1'b0;
- cnt_in=load_value;
- @(negedge clk);
- load_1=1'b1;
- end
- endtask
- endmodule
复制代码
下面是计数器的代码
- `timescale 1ns/100ps
- module count16(count,count_tri,clk,rst_1,load_1,enable_1,cnt_in,oe_1);
- output [3:0] count;
- output [3:0]count_tri;//tri_state buffers
- input clk;
- input rst_1;
- input load_1;
- input enable_1;
- input [3:0] cnt_in;
- input oe_1;
- reg [3:0] count;
- assign count_tri=(!oe_1) ? count : 4'bZZZZ;
- always @ (posedge clk or negedge rst_1)
- begin
- if(!rst_1)
- begin
- count<=#1 4'b0000;
- end
- else if(!load_1) begin count<=#1 4'b1010;
- end
- else if(!enable_1) //enable_1 is the enable signal of counting.
- begin
- count<=#1 count+1;
- end
- end
- endmodule
复制代码
