查看: 4895|回复: 4
运行nanosim-vcs时遇到PRODUCT LICENSE NOT AVAILABLE FOR "nanosim
发表于 2013-10-1 19:18:54 | 显示全部楼层 |阅读模式
各位好:    我在去行nanosim自带的example vco时可以跑完,但是
     在运行tutorial中的NS-VCS时,在simv +COMPILE之后出现下面的error:    ***** Warning: Stacksize soft limit 10240 K is too small, we prefer more than 60000 K,
               please use csh command " limit stacksize 60000 " to set it.
Chronologic VCS simulator copyright 1991-2013
Contains Synopsys proprietary information.
Compiler version H-2013.06; Runtime version H-2013.06;  Oct  1 04:06 2013
|             NanoSim Version F-2011.09-SP2              |
|                    SN:20120217-linux                   |
|           Machine Name: localhost.localdomain          |
| Copyright (c) 2011 Synopsys Inc., All Rights Reserved. |
Built by nsmgr   on Fri Feb 17 01:36:52 PST 2012
Tue Oct  1 04:06:29 PDT 2013
The 32-bit version of the simulator is running.
Initializing system messages ...
Initializing system messages took 0.010 s
ERROR:NanoSim:0x3110140fRODUCT LICENSE NOT AVAILABLE FOR "nanosim"
Error-[MSV-INTERFACE-ERROR] Mixed-Signal Interface Error
  Internal Error in Mixed-Signal cosim flow.
   ' aborting ...
Segmentation violation - signal 11
Please send the following information to Synopsys support along with a testcase.
|                    SN:20120217-linux                   |
"23528692 15709216 18854074 18860655 18918347 134601680 -1230068510 1780551 1783080 134595597 18789813 31254150 31239975 22259008 20518899 18910427 18871650 18889638 134617432 134621030 -1226734291 -1226408596 -1226402095 -1231643846 134558289 -1231719711 -1231718844 -1230174839 -1229983258 134558456 4050588 "
我看论坛中之前也有人遇到过这个问题,但是没有提出解决方法。不知能否遇到解决了这个问题的人给一些建议?
注:我的环境installv3.0 , scl10.9.3
    vcs2012, 2013, ns 2011, 2012, 2013我都试过了,都有这个问题。
 楼主| 发表于 2013-10-2 10:44:41 | 显示全部楼层
自己顶一个,等待解答
发表于 2015-11-3 19:40:52 | 显示全部楼层
回复 1# creese
    目前也遇到这个问题,请问下后来你是怎么解决的啊?
发表于 2017-11-13 18:34:15 | 显示全部楼层
回复 1# creese
“  vcs2012, 2013, ns 2011, 2012, 2013我都试过了”
你好啊,可以分享一下你用的这些软件吗?实在太难找了,特别是lic。我刚开始学nanosim+vcs,困难重重。
发表于 2018-1-19 11:02:19 | 显示全部楼层
刚安装完nanosim,但不知道怎么设置变量,有没有教程什么的
GMT+8, 2025-12-25 22:45 , Processed in 0.024274 second(s), 7 queries , Gzip On, Redis On.
