查看: 2246|回复: 1
[求助] 怎么消除直流成分
发表于 2013-9-26 23:09:52 | 显示全部楼层 |阅读模式
用MATLAB查看Sigma delta调制器电路级设计的PSD,发现低频直流成分很大,有什么方法可以把其中的直流成分去掉?具体算法或者仿真代码该怎么写?
[img=300,300][/img]
发表于 2013-9-27 07:13:10 | 显示全部楼层
1.remove them from FFT result
2.if your system has DC component use post high pass digital filter (1~2 order IIR, after decimator) to remove them
GMT+8, 2025-12-28 01:39 , Processed in 0.012103 second(s), 3 queries , Gzip On, Redis On.
