查看: 2706|回复: 7
[求助] 求一篇12位SAR的paper
发表于 2013-9-25 11:34:53 | 显示全部楼层 |阅读模式
Low Power 12-bit SAR ADC for Autonomous Wireless Sensors Network Interface
Abstract
Design strategies for power effective and high resolution successive-approximation ADCs for autonomous multi-sensor systems are discussed. Specifically, an optimisation for lowest possible power consumption of comparators is addressed and evaluated using both simulations and measurements of a fabricated Si test-chip. The proposed design solution is capable to provide a 12-bit resolution at 50-kHz with only 0.1 muW power consumption on a 1.2-V supply. The achieved Figure-of-Merit is 165 fJ/convertion-step is, to our knowledge, the best ever reported. The complete ADC area is 0.35 mm2 in NXP 0.14 mum CMOS technology with only three metal layers.
Published in:
Advances in sensors and Interfaces, 2009. IWASI 2009. 3rd International Workshop on
Date of Conference: 25-26 June 2009
A 3.3 V 12 bits railto- rail ADC SAR for neuronal implant
This paper presents the development of a low-power rail-to-rail SAR-ADC to be used in a medical implants. The first part discusses the principle schematic and the requirements for the neuronal implant application. Additionally, a full description of each part of this ADC SAR will be given. And finally the last part presents measurement results of a fabricated test chip in 0.35μM CMOS technology, with 86μW of power consumption, 12bits of resolution, and a speed of 24Ks/S.
Published in:
NEWCAS Conference (NEWCAS), 2010 8th IEEE InternationalDate of Conference: 20-23 June 2010
发表于 2013-9-25 18:25:59 | 显示全部楼层
05184780.pdf (873.51 KB , 下载次数: 58 )
发表于 2013-9-25 18:52:35 | 显示全部楼层
学习一下!
 楼主| 发表于 2013-9-25 19:01:45 | 显示全部楼层
回复 2# ac3m666
   谢谢!
发表于 2013-9-26 01:47:00 | 显示全部楼层
支持支持,非常感谢
发表于 2016-7-8 08:40:23 | 显示全部楼层
THANK YOU
发表于 2016-8-11 14:29:01 | 显示全部楼层
发表于 2018-2-2 15:24:59 | 显示全部楼层
感谢楼主分享
GMT+8, 2025-12-27 10:20 , Processed in 0.027945 second(s), 7 queries , Gzip On, Redis On.
