查看: 3340|回复: 5
运行Synopsys上的GENESISe报错,求解答~~~~~
发表于 2013-9-21 11:30:47 | 显示全部楼层 |阅读模式
我将Synopsys安装好了,但是运行后报错,信息如下:
[supen@localhost bin]$ ./GENESISe
License lookup failed: Cannot find license file.
The license files (or license server system network addresses) attempted are
listed below.  Use LM_LICENSE_FILE to use a different license file,
or contact your software provider for a license file.
Feature:       swb_all
License path:  /home/supen/install/license/sysnopsys.dat
FLEXnet Licensing error:-1,234.  System Error: 2 "No such file or directory"
For further information, refer to the FLEXnet Licensing End User Guide,
available at "www.macrovision.com"..
* feature is "swb_all"
* version is "2013.03"
* STROOT is "/home/supen/install/sentaurus/bin/./.."
* hostname is "localhost.localdomain"
* display is "/dev/pts/0"
* user is "supen"
[supen@localhost bin]$求解答~~~~~~~~
 楼主| 发表于 2013-9-21 14:34:06 | 显示全部楼层
求解答啊~~~~~~~~~~·
发表于 2013-9-22 09:49:22 | 显示全部楼层
license 缺 swb_all这个feature,自己在src里加入,重新生成license
 楼主| 发表于 2013-9-22 10:31:19 | 显示全部楼层
回复 3# abab1394 怎么修改,有教程么?谢谢您~~~~~~~
发表于 2013-9-22 16:38:35 | 显示全部楼层
回复 4# supen
    坛子里多的很
发表于 2013-12-8 21:44:39 | 显示全部楼层
回复 4# supen
遇到同样问题,请问您最后解决了么? 求助啊!
GMT+8, 2025-12-25 23:40 , Processed in 0.024750 second(s), 7 queries , Gzip On, Redis On.
