查看: 5726|回复: 15
PCI Bus Demystified (EBook)
发表于 2007-2-21 14:36:13 | 显示全部楼层 |阅读模式
Introduction ......................................................................... 1
Intended Audience ....................................................................... 2
The Rest of This Book .................................................................. 3
Chapter 1: Introducing the Peripheral Component
Interconnect (PCI) Bus .......................................................... 5
So What is a Computer Bus? ........................................................ 6
Bus Taxonomy............................................................................... 7
What’s Wrong with ISA and Attempts to Fix It ......................... 9
The VESA Local Bus.................................................................. 10
Introducing PCI .......................................................................... 11
Features ....................................................................................... 11
The PCI Special Interest Group ................................................. 12
PCI Signals ................................................................................. 13
Signal Groups ............................................................................. 13
Signal Types ................................................................................ 18
Sideband Signals ......................................................................... 19
Definitions .................................................................................. 20
Summary ..................................................................................... 21
Chapter 2: Arbitration ....................................................... 22
The Arbitration Process ............................................................. 22
An Example of Fairness .............................................................. 25
Bus Parking ................................................................................. 26
Latency........................................................................................ 27
Summary ..................................................................................... 31
Chapter 3: Bus Protocol ..................................................... 32
PCI Bus Commands .................................................................... 32
Basic Read/Write Transactions ................................................... 34
Transaction Termination — Master ........................................... 45
Transaction Termination — Target ............................................ 45
Error Detection and Reporting ................................................... 51
Summary ..................................................................................... 54
Chapter 4: Optional and Advanced Features ..................... 56
Interrupt Handling ..................................................................... 56
The Interrupt Acknowledge Command ..................................... 59
“Special” Cycle ........................................................................... 60
64-bit Extensions ........................................................................ 62
Summary ..................................................................................... 66
Chapter 5: Electrical and Mechanical Issues ..................... 67
A “Green” Architecture ............................................................. 67
Signaling Environments — 3.3V and 5V .................................. 70
5 Volt Signaling Environment.................................................... 72
3.3 Volt Signaling Environment................................................. 77
Timing Specifications ................................................................. 81
66 MHz PCI ................................................................................ 85
Mechanical Details ..................................................................... 88
Summary ..................................................................................... 90
Chapter 6: Plug and Play Configuration ............................ 92
Background ................................................................................. 92
Configuration Address Space ..................................................... 93
Configuration Header — Type 0 ................................................ 95
Base Address Registers (BAR) ................................................. 103
Expansion ROM ....................................................................... 107
Capabilities List ........................................................................ 110
Vital Product Data .................................................................... 111
Summary ................................................................................... 115
Chapter 7: PCI BIOS ......................................................... 116
Operating Modes ...................................................................... 116
Is the BIOS There? ................................................................... 117
BIOS Services ........................................................................... 118
Generate Special Cycle ............................................................ 120
Summary ................................................................................... 124
Chapter 8: PCI Bridging ................................................... 125
Bridge Types .............................................................................. 125
Configuration Address Types.................................................... 128
Configuration Header — Type 1 .............................................. 129
Bus Hierarchy and Bus Number Registers ................................ 130
Address Filtering — the Base and Limit Registers ................... 132
Prefetching and Posting to Improve Performance ................... 135
Interrupt Handling Across a Bridge ......................................... 136
Bridge Support for VGA — Palette “Snooping”...................... 140
Resource Locking ...................................................................... 142
Summary ................................................................................... 146
Chapter 9: CompactPCI .................................................... 148
Why CompactPCI? ................................................................... 148
Mechanical Implementation .................................................... 150
Electrical Implementation ........................................................ 155
CompactPCI Bridging .............................................................. 162
Summary ................................................................................... 165
pci_bus_demystified.pdf
1.81 MB, 下载次数: 220 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2007-2-22 18:41:52 | 显示全部楼层
哪年、哪个出版社出版的?
 楼主| 发表于 2007-2-22 22:26:53 | 显示全部楼层
回复 #2 dsp2008 的帖子
2000 by LLH Technology Publishing
 楼主| 发表于 2007-3-15 11:32:13 | 显示全部楼层
ziji dingyiding
发表于 2007-5-14 11:54:45 | 显示全部楼层
看看,谢谢
发表于 2007-5-19 11:45:40 | 显示全部楼层
DOWNLOAD OK, 谢谢分享
发表于 2007-6-27 00:18:35 | 显示全部楼层
谢谢分享
发表于 2009-9-22 14:49:02 | 显示全部楼层
我现在急要。谢谢。
发表于 2009-12-12 10:29:15 | 显示全部楼层
下载了 谢谢分享~
发表于 2010-1-5 17:04:40 | 显示全部楼层
呵呵,谢谢!好东西啊,开始害怕找不到,想不到在这里有,真是难得~
GMT+8, 2025-12-18 20:20 , Processed in 1.138703 second(s), 9 queries , Gzip On, Redis On.
