查看: 3139|回复: 2
[求助] 综合碰到的一个error
发表于 2013-9-4 05:04:01 | 显示全部楼层 |阅读模式
综合碰到了一个error如下。但是error的单引号里是空的,请问我怎么去查error在哪,error是啥呢?我用的RTL compiler,这个错误是发生在最后一步synthesize -to_mapped. verilog code和tcl 附在后面了,求大神帮忙看看。谢谢。
Error   : A required object parameter could not be found. [TUI-61] [get_attribute]
        : An object named '' could not be found.
        : Check to make sure that the object exists and is of the correct type.  The 'what_is' command can be used to determine the type of an object.
Usage: get_attribute  <string> [<object>+]
    <string>:
        attribute name
    [<object>+]:
        object of interest (must be unique)
-------------verilog code------------
module test1
    clk,
    rst,
    x_in,
    y_in,
    x_out
input clk,rst;
input [15:0] x_in, y_in;
output [15:0] x_out;
reg [15:0] x_out;
wire flag;
assign flag = x_in[15];
always @(posedge clk or negedge rst)
if (~rst)
x_out<='d0;
else
begin
if (flag)
x_out<=x_in+y_in;
else
x_out<=x_in-y_in;
end
endmodule
----------------------------tcl-----------------------------------------------------------------------
set_attribute lib_search_path {/users/bh/class/CPE411/STD/Synopsys}
set_attribute library {/users/bh/class/CPE411/STD/Synopsys/smic13_ff_1p32v_0c.lib}
read_hdl -v2001 {/users/bh/class/CPE411/syn1/source/test1.v}
set target_technology smic13_ff_1p32v_0c
elaborate
check_design
read_sdc -stop_on_errors /users/bh8/class/CPE411/syn1/script/timing.sdc
发表于 2013-9-4 10:03:45 | 显示全部楼层
VerlogHDL没有任何问题,你的tcl文本好像有一些问题,在写法上与我见过的不太一样,但是在这方面只是会用说不出问题所在,海涵。
发表于 2013-9-8 20:13:20 | 显示全部楼层
读入的verdilog
GMT+8, 2025-12-29 06:59 , Processed in 0.023777 second(s), 7 queries , Gzip On, Redis On.
