查看: 11017|回复: 6
[求助] 请教Pipelined ADC的REFT,REFB buffer的设计
发表于 2013-8-25 20:46:32 | 显示全部楼层 |阅读模式
在pipelind ADC中,MDAC的开关电容需要有REFT和REFB电平,负载的开关电容切换会使得buffer输出端产生跳变,这时候要求两个buffer能够快速回复到所需电平,也就是建立时间要足够小,如果在上GHz的工作频率下这个建立时间可能就是几百ps。
那对于高速应用,这两个buffer的指标是否要满足带宽也要上GHz,什么样的结构合适呢?
如果在buffer输出端接一个大电容(ex. 100pF)来滤掉开关电容产生的波动是否现实,这是否又会引入一个问题:buffer的带宽会降到很低?
希望各位大神多给点指导意见,多谢哈!
发表于 2013-8-26 15:40:59 | 显示全部楼层
DING YI XIA ,
发表于 2013-8-26 17:00:22 | 显示全部楼层
还有,想问一下,在buffer后接一个大电容稳定电压,但是buffer的相位裕度是怎样处理的,
还是要求相位裕度要>60吗?
发表于 2014-6-28 16:57:44 | 显示全部楼层
s & h !
发表于 2014-9-25 01:25:23 | 显示全部楼层
xvvxcvxcvcxvcxv
发表于 2014-9-28 14:20:25 | 显示全部楼层
I once designed a 8 bit 30MHZ pipeline adc, the reference buffer is integrated, so I just use 2 such kinds of buffer to get them. Between the VREFP and VREFN  I gave a 10pF caps, which make the delta between VREFP and VREFN is the same when the switch on/off. The testing results OK.
     For high resolution and high speed , I think there is a trade between the buffer response time and the output capacitance. Large capacitance will make the switching on/off impact decreasing but the buffer BW will decrease too.
发表于 2016-4-3 16:41:13 | 显示全部楼层
you added a large capacitor, which is useful but you need added a large off chip capacitor and added 2 pins.
GMT+8, 2025-12-16 09:11 , Processed in 0.277887 second(s), 7 queries , Gzip On, Redis On.
