楼主: guolehaohao
[原创] windows 7 下modelsim 10.0d配置UVM_1.1d
发表于 2015-12-20 14:06:58 | 显示全部楼层
已经成功,多谢分享
发表于 2015-12-22 15:53:14 | 显示全部楼层
谢谢分享
发表于 2016-1-10 12:38:48 | 显示全部楼层
好多东西
发表于 2016-4-19 16:05:26 | 显示全部楼层
dawdaawfaefff
发表于 2016-4-27 22:07:27 | 显示全部楼层
按楼主的方法弄了一遍,helloworld已经跑成功了,可是自己的工程还是报错
# ** Error: ../00_Vip/01_lbus/lbus_transfer.sv(14): Field/method name (m_do_cycle_check) not in '__m_uvm_status_container'
# ** Error: ../00_Vip/01_lbus/lbus_transfer.sv(14): Field/method name (m_uvm_cycle_scopes) not in '__m_uvm_status_container'
# ** Error: ../03_Test/pcie_tlp.sv(5): Enum. lit. 'MRd_3DW' width (7) must match enum's (32).
# ** Error: ../03_Test/pcie_tlp.sv(6): Enum. lit. 'MRd_4DW' width (7) must match enum's (32).
# ** Error: ../03_Test/pcie_tlp.sv(7): Enum. lit. 'MRdLk_3DW' width (7) must match enum's (32).
# ** Error: ../03_Test/pcie_tlp.sv(8): Enum. lit. 'MRdLk_4DW' width (7) must match enum's (32).
# ** Error: ../03_Test/pcie_tlp.sv(9): Enum. lit. 'MWr_3DW' width (7) must match enum's (32).
# ** Error: ../03_Test/pcie_tlp.sv(10): Enum. lit. 'MWr_4DW' width (7) must match enum's (32).
# ** Error: ../03_Test/pcie_tlp.sv(11): Enum. lit. 'IORd' width (7) must match enum's (32).
# ** Error: ../03_Test/pcie_tlp.sv(12): Enum. lit. 'IOWr' width (7) must match enum's (32).
# ** Error: ../03_Test/pcie_tlp.sv(13): Enum. lit. 'CfgRd0' width (7) must match enum's (32).
# ** Error: ../03_Test/pcie_tlp.sv(14): Enum. lit. 'CfgRd1' width (7) must match enum's (32).
# ** Error: ../03_Test/pcie_tlp.sv(15): Enum. lit. 'CfgWr0' width (7) must match enum's (32).
# ** Error: ../03_Test/pcie_tlp.sv(16): Enum. lit. 'CfgWr1' width (7) must match enum's (32).
# ** Error: ../03_Test/pcie_tlp.sv(17): Enum. lit. 'TCfgRd' width (7) must match enum's (32).
# ** Error: ../03_Test/pcie_tlp.sv(18): Enum. lit. 'TCfgWr' width (7) must match enum's (32).
这是什么原因呢
 楼主| 发表于 2016-4-29 16:33:11 | 显示全部楼层
回复 75# tangxijun
你可以百度一下的,这个问题一点都不复杂
发表于 2016-5-10 10:55:04 | 显示全部楼层
Thank you very much
发表于 2016-5-11 16:46:49 | 显示全部楼层
64位ModelSim里面测试,可以编译文件,但是仿真时候报错
发表于 2016-5-11 16:47:57 | 显示全部楼层
而且没有uvm_pkg.dll文件
发表于 2016-5-11 17:02:48 | 显示全部楼层
GMT+8, 2025-12-19 13:56 , Processed in 0.021121 second(s), 5 queries , Gzip On, Redis On.
