发表于 2006-11-25 14:52:03
显示全部楼层
谢谢楼主。照例给出在亚马逊的链接。
http://www.amazon.com/Analog-Cir ... Allen/dp/0195116445
Editorial Reviews
Review
Chapter 1. Introduction to CMOS Analog Circuit Design 1.1. Analog Integrated Circuit Design 1.2. Notation, Symbology and Terminology 1.3. Analog Signal Processing 1.4. Example of Analog VLSI Mixed-Signal Circuit Design Chapter 2. CMOS Technology 2.1. Basic MOS Semiconductor Fabrication Processes 2.2. The PN Junction 2.3. The MOS Transister 2.4. Passive Components 2.5. Other Considerations 2.6. Integrated Circuit Layout Chapter 3. CMOS Device Modeling 3.1. Simple MOS Large-Signal Model (SPICE LEVEL 1) 3.2. Other MOS Large-Signal Model Parameters 3.3. Small-Signal Model for the MOS Transistor 3.4. SPICE Level 3 Model 3.5. Subthreshold MOS Model 3.6. BSIM MOS Model 3.7. BJT Large and Small Signal Model 3.8. SPICE Simulation of MOS Circuits Chpater 4. Analog CMOS Subcircuits 4.1. MOS Switch 4.2. MOS Diode/Active Resistor 4.3. Current Sinks and Sources 4.4. Current Mirrors and Current Amplifiers 4.5. Current and Voltage References 4.6. Bandgap Voltage Reference Chapter 5. CMOS Single Stage Amplifiers 5.1. Simple Inverters 5.2. Differential Amplifier 5.3. Cascode Amplifier 5.4. Transconductance Amplifiers 5.5. Current Amplifiers 5.6. Output Amplifiers/Buffers Chapter 6. Simple Operational Amplifiers 6.1. Development of the Two-Stage Op Amp 6.2. Compensation of the Two-Stage Op Amp 6.3. Design of the Two-Stage Op Amp 6.4. Folded-Cascode Op Amp Design 6.5. Push-Pull, Two-Stage Op Amp 6.6. Simulation and Measurement of Op Amps Chapter 7. Complex Operational Amplifiers 7.1. Buffered Op Amps 7.2. High Frequency Op Amps 7.3. Micropower Op Amps 7.4. Low Noise Op Amps 7.5. Low Voltage Op Amps 7.6. Differential Output Op Amps Chapter 8. Comparators 8.1. Characterization of Comparators 8.2. Two-Stage Comparator Design 8.3. Autozeroing 8.4. Regenerative Comparators 8.5. High-Speed Comparators Chapter 9. Switched Capacitor Circuits 9.1. Switched Capacitor Circuits 9.2. Switched Capacitor Amplifiers 9.3. Switched Capacitor Integrators 9.4. Z-Domain Models of Two-Pases, Switched Capacitor Circuits 9.5. First-Order Switched Capacitor Circuits 9.6. Second-Order Switched Capacitor Circuits 9.7. Switched Capacitor Filters Chapter 10. Digital-Analog and Analog-Digital Converters 10.1. Introduction to Digital-Analog Converters 10.2. Current, Voltage, and Charge Scaling Digital-Analog Converters 10.3. Improved Digital-Analog Converter Performance 10.4. Serial Digital-Analog Converters 10.5. Introduction to Analog-Digital Converters and S/H Circuits 10.6. Serial Analog-Digital Converters 10.7. Medium Speed Analog-Digital Converters 10.8. High Speed Analog-Digital Converters Chapter 11. Analog Signal Processing Circuits 11.1. Waveshaping Circuits 11.2. Multipliers 11.3. Oscillators 11.4. Phase-Locked Loops 11.5. Modems 11.6. Continuous Time Filters Chapter 12. CMOS Radio Frequency Integrated Circuit Design 12.1. Introduction and Background 12.2. Low Noise Amplifiers 12.3. Frequency Synthesizers 12.4. Mixers: Up-Conversion and Down-Conversion 12.5. Filters--RF and IF 12.6. Analog-Digital and Digital-Analog Converters 12.7. Power Amplifiers Appendix Circuit Principles Analysis Techniques Elmore Delay Parameter Extraction Basic Device Physics Noise Principles Time/Frequency Domain Relationships for Second-Order Functions
Book Description
Respected authors Phillip E. Allen and Douglas R. Holberg have combined their expertise as engineers and academics in this new edition of CMOS Analog Circuit Design. Including technological changes that have taken place since the first edition, this up-to-date work presents an effective overview of the principles and techniques for designing circuits to be implemented in CMOS technology. The two main goals of the text are to teach the methodology of analog integrated circuit design by using a hierarchically-organized approach and to mix the academic and practical viewpoints in a treatment that is neither superficial nor overly detailed. The industrial experience and knowledge of the authors have supplied many of the circuits, techniques, and principles presented in the book, making it a valuable resource for both practicing engineers and students taking courses in analog electronics or CMOS analog design. The trademark approach of Allen and Holberg's book is its design recipes, which take the reader step-by-step through the creation of real circuits, explaining and increasing understanding of complex design problems. The book provides detailed coverage of an often-neglected area and deliberately leaves out bipolar analog circuits, since CMOS is the dominant technology for analog integrated circuit design. Appropriate for seniors and graduate students with background knowledge in basic electronics including biasing, modeling, circuit, analysis and some familiarity with frequency response, CMOS Analog Circuit Design, Second Edition, presents a complete picture of design (including modeling, simulation, and testing) and enables readers to undertake the design of an analog circuit that can be implemented by CMOS technology. |
