查看: 4451|回复: 4
[求助] LINUX虚拟机环境下 modelsim 生成fsdb时出现错误
发表于 2013-7-30 16:37:43 | 显示全部楼层 |阅读模式
首先报warning
# *Novas* WARN:
#   <ModelSim61> will be deprecated in an upcoming release.
#   Please use NEW dumper instead with the following instructions.
#   1. Set shared library path to ${NOVAS_INST}/share/PLI/MODELSIM/${PLATFORM}
#      %setenv LD_LIBRARY_PATH ${NOVAS_INST}/share/PLI/MODELSIM/${PLATFORM}
#   2. Re-run simulation and link new objects files for FSDB dumping.
#      %vsim top -pli novas_fli.so
#   Refer to the ${NOVAS_INST}/doc/linking_dumping.pdf manual for complete details.
# *Novas* Create FSDB file './wave/tb_pcie_packet.fsdb'
# *Novas* Begin traversing the scope(tb_top.sbc_top_u), layer(0).
# *Novas* End of traversing the scope(tb_top.sbc_top_u)
然后报错
# tb_top.u_nand_model_00.uut_0.INFO at time 100.000 ns: PowerUp Complete.
... Insufficient memory ...
... (memoryUsed=0 wanted=1048576) ...
# Attempting stack trace sig  6
# Signal caught: signo [6]
# vsim_stacktrace.vstf written
# Current time Tue Jul 30 16:04:15 2013
# ModelSim Stack Trace
# Program = vsim
# Id = "6.5e"
# Version = "2010.02"
# Date = "Feb 26 2010"
# Platform = linux
# 0    0xb7fa1410: '<unknown (@0xb7fa1410)>'
# 1    0x005016fc: '<unknown (@0x5016fc)>'
# 2    0xb6c9ea62: '<unknown (@0xb6c9ea62)>'
# 3    0xb6c9eab7: '<unknown (@0xb6c9eab7)>'
# 4    0xb6c96dce: '<unknown (@0xb6c96dce)>'
# 5    0xb6ca1306: '<unknown (@0xb6ca1306)>'
# 6    0xb6c90e29: '<unknown (@0xb6c90e29)>'
# 7    0xb6c90877: '<unknown (@0xb6c90877)>'
# 8    0xb6ca0d3f: '<unknown (@0xb6ca0d3f)>'
# 9    0xb6c65439: '<unknown (@0xb6c65439)>'
# 10   0x080624ab: '<unknown (@0x80624ab)>'
# 11   0x08129784: '<unknown (@0x8129784)>'
# End of Stack Trace
** Fatal: (SIGABRT) Bad pointer access. Closing vsimk.
** Fatal: vsimk is exiting with code 206.
(Exit codes are defined in the ModelSim messages appendix
of the ModelSim User's Manual.)
# ** Warning: (vsim-3116) Problem reading symbols from /lib/libc.so.6.
# Cannot allocate memory. (errno = ENOMEM)
# ** Warning: (vsim-3116) Problem reading symbols from /home/fangjian/tools/verdi/verdi/share/PLI/modelsim_pli_latest/LINUX/libpli.so.
# ** Warning: (vsim-3116) Problem reading symbols from /usr/modelsim_65f/modeltech/linux/vsimk.
请遇到类似情况的朋友指教
发表于 2013-11-8 14:27:05 | 显示全部楼层
你应该将LM_LICENSE_FIEL只指定给modelsim.这样这个问题就解决了.
发表于 2013-12-7 04:39:13 | 显示全部楼层
DO you have docs?
发表于 2013-12-26 15:00:50 | 显示全部楼层
顶一个
发表于 2014-1-22 11:53:35 | 显示全部楼层
非常感谢 顶一个
GMT+8, 2025-12-27 13:12 , Processed in 0.017161 second(s), 5 queries , Gzip On, Redis On.
