发表于 2014-8-3 20:08:10
显示全部楼层
1 Introduction!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-
1.1 Motivation!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-1
1.2 Dissertation organization!-!-!-!-!-!-!-!-!-!-!!-!-!-!-!-!-!-!
References!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!11
2 Assisting the ADC in digital domain with a novel, negative-group-delay-assisted,
digital, interference canceller!-!-!-!-!-!-!-!-!-!-!-!-!-!-
2.1 Background!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-
2.2 The delay mismatch issue in DAIC!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-
2.3 Resolving the delay mismatch issue using a novel, linear predictor with negative group delay!-!-!-!-.
2.4 Numerical solution!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-25
2.5 Optimal choice of design parameters!-!-!-!-!-!-!-!-!-!-!-!-!-!28
2.6 Application of the DAIC to the mm-wave scenario!-!-!-!-!-!-!-!-!-!-!-.32
2.7 Experimental results!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-
2.8 Chapter conclusion and summary!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-
References!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!41
3 Assisting the frequency synthesizer in digital domain with a novel, phase noise track-
and-correct system!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!
3.1 Introduction!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-
3.2 Previous remedies to the phase noise issue!-!!-!-!-!-!-!-!-!-!-!-!-!-!-!
3.3 A novel, generic, cross-domain, phase noise track-and-correct (PNTC) technique!-!-!-!-!-!-!
3.4 Simulation studies!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-
3.5 Application of PNTC to the mm-wave scenario!-!-!-!-!-!-!-!-!-!-!-!-!-!
3.6 Implementation considerations!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!
3.7 Chapter conclusion and summary!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-
References!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!67
4 Assisting the antenna array in analog baseband domain with a low-power baseband
time-alignment technique!-!-!-!-!-!-!-!-!-!-!-!-!69
4.1 Introduction!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-
4.2 Beam-squinting and array-induced frequency fading issues!-!-!-!-!-!-!-!-!-75
4.3 The proposed cross-domain solution!-!-!-!-!-!-!-!-!-!-!-!-!-!82
4.4 Application of BTA to the mm-wave scenario!-!-!-!-!-!-!-!-!-!-!-!-!-!
4.5 Implementation considerations!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!
4.6 Power saving figure of merit!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-
4.7 Chapter conclusion and summary!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!
References!-!-!-!-!!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-
5 Conclusions and suggestion for future works!-!-!-!-!-!-!-!-94
5.1 Conclusions!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-!-
5.2 Suggestions for future works!-!-!-!-!-!-!-!-!-!-!-!!-!-!-!-!- |
