查看: 1949|回复: 0
[资料] A 20nm 1.8V 8Gb PRAM (PCM) with 40MB/s Program Bandwidth
发表于 2013-7-22 10:55:49 | 显示全部楼层 |阅读模式
Phase-change random access memory (PRAM) is considered as one of the most
promising candidates for future memories because of its good scalability and
cost-effectiveness [1]. Besides implementations with standard interfaces like
NOR flash or LPDDR2-NVM, application-oriented approaches using PRAM as
main-memory or storage-class memory have been researched [2-3]. These
studies suggest that noticeable merits can be achieved by using PRAM in
improving power consumption, system cost, etc. However, relatively low chip
density and insufficient write bandwidth of PRAMs are obstacles to better system
performance. In this paper, we present an 8Gb PRAM with 40MB/s write
bandwidth featuring 8Mb sub-array core architecture with 20nm diode-switched
PRAM cells [4]. When an external high voltage is applied, the write bandwidth
can be extended as high as 133MB/s.
Samsung_8G.pdf
2.52 MB, 下载次数: 48 , 下载积分: 资产 -2 信元, 下载支出 2 信元
GMT+8, 2025-11-5 00:34 , Processed in 0.014908 second(s), 4 queries , Gzip On, Redis On.
