查看: 4436|回复: 4
[求助] 求助,calibre pex提取schematic!!
发表于 2013-7-18 19:22:53 | 显示全部楼层 |阅读模式
初学数字后端设计,遇到一些问题请大牛们帮我解答!
我是用smic013工艺库,想将GDS文件从Encounter中导入到icfb中用pex提取schematic,然后运行pex的时候总是出现:
WARNING: Top level port name "dp_cluster_36\/N10532" at location (519.11,198.235) on net 405 not valid for netlisting; net id used instead.
WARNING: Top level port name "add_1_root_add_0_root_add_5925_2/carry[8]" at location (520.03,213.815) on net 5438 not valid for netlisting; net id used instead.
WARNING: Top level port name "add_0_root_add_0_root_add_5555_2/carry[1]" at location (520.49,83.845) on net 1610 not valid for netlisting; net id used instead.
WARNING: Top level port name "add_0_root_sub_0_root_sub_6118_3/carry[3]" at location (520.49,201.925) on net 1878 not valid for netlisting; net id used instead.
WARNING: Top level port name "add_0_root_add_1_root_sub_5567_3_cf/carry[1]" at location (520.95,72.775) on net 3856 not valid for netlisting; net id used instead.
WARNING: Top level port name "add_0_root_add_0_root_add_5925_2/carry[2]" at location (520.95,105.985) on net 1611 not valid for netlisting; net id used instead.
类似这样的warning, 我想问为什么port name 会不合法啊?难道太长了?
发表于 2017-9-29 10:57:04 | 显示全部楼层
挖坟来了,这个是什么原因还能想起来吗
发表于 2018-7-8 00:03:48 | 显示全部楼层
who know it?
发表于 2022-11-17 09:40:23 | 显示全部楼层
顶顶 同样的问题
发表于 2022-11-18 10:40:34 | 显示全部楼层
问题已解决,是工具自动打了多余的text。工具在这里识别成port了
GMT+8, 2025-11-18 15:05 , Processed in 0.028167 second(s), 8 queries , Gzip On, Redis On.
