查看: 3947|回复: 2
[求助] 【求助】ICC中check_library出现的LIBCK-213如何解决?
发表于 2013-7-14 10:30:46 | 显示全部楼层 |阅读模式
如下所示:
Error: List of pins mismatched in logic and physical libraries (LIBCHK-213)
Logic library:    saed90nm_max
Physical library: /home/IC/ICC_lab/lab1/ORCA/ref/saed90nm_fr
                                          Pin direction           Pin type
Cell name                    Pin name    Logic   Physical     Logic         Physical
TIEH                         VDD         output  Output      signal         power
TIEL                         VSS         output  Output      signal         ground
发表于 2013-7-14 22:57:18 | 显示全部楼层
此错误可以前期忽略,谢谢!
发表于 2013-7-14 22:58:13 | 显示全部楼层
此错误可以忽略,谢谢
GMT+8, 2025-12-24 16:35 , Processed in 0.020060 second(s), 6 queries , Gzip On, Redis On.
