查看: 2852|回复: 7
Radio Resource Management Strategies in UMTS_part01
发表于 2007-1-29 22:50:53 | 显示全部楼层 |阅读模式
Radio Resource Management Strategies in UMTS 01The key feature of future mobile communication systems is the ability to deliver wideband and high bit-rate multimedia services alongside the traditional radio services such as voice, messaging and slow rate data. The broad range of services expected to be supported can be divided into different Quality of Service (QoS) classes. However, the provision of such mobile multimedia services under QoS guarantees will not be possible without a utilization of the air interface resources by means of Radio Resource Management (RRM) strategies that ensure the target QoS, the planned coverage area and that offer a high system capacity. Under this framework, the book focuses on the RRM concepts, including the theoretical background that serves as a basis for the description of specific RRM algorithms. The RRM problem for UMTS is presented, and more specifically, for the FDD mode, which is based on a WCDMA scheme. More specifically, the different aspects that are covered include:
  • Introduces the mobile communications sector and UMTS, including the evolution towards 4G systems, with an overview of the QoS concept which is key for the definition of RRM strategies
  • Offers a detailed description of the radio interface in UMTS, as the basis for the implementation of RRM strategies
  • Provides the fundamental concepts related with the development of RRM strategies in WCDMA networks
  • Analyses particular RRM algorithms in a variety of scenarios, trying to identify the key parameters and factors that influence their performance
  • Explores the evolution of UMTS towards Beyond 3G systems and the concept of Common RRM in heterogeneous networks with the aid of some algorithm examples
This comprehensive title is essential reading for engineers and managers in radio engineering departments of UMTS network operators and UMTS equipment manufacturers. It will also prove insightful to researchers in the field of 3G and Beyond 3G systems and academics in any of these areas.
Preface. List of Acronyms. 1 Introduction. 1.1 The mobile communications sector. 1.2 UMTS. 1.3 QoS model in UMTS. References. 2 CDMA Concepts. 2.1 Multiple access techniques. 2.2 CDMA signal generation. 2.3 CDMA signal reception. 2.4 CDMA in cellular systems. References. 3 UMTS Radio Interface Description. 3.1 The UMTS protocols. 3.2 Radio interface protocol structure. 3.3 Physical layer. 3.4 Layer 2 protocols. 3.5 Radio Resource Control (RRC) protocol. 3.6 Examples of Radio Access Bearers. References. 4 Basics of RRM in WCDMA. 4.1 Radio Resource concept. 4.2 Radio network planning. 4.3 Radio Resource Management. 4.4 Air interface characterization. 4.5 RRM functions. 4.6 System characteristics relevant at RRM level. References. Appendix - Path loss distribution. 5 RRM Algorithms. 5.1 RRM algorithm evaluation methodology. 5.2 Admission control algorithms. 5.3 Handover and cell selection algorithms. 5.4 Congestion control algorithms. 5.5 Short term RRM algorithms. 5.6 Power control. References. Appendix - Simulation models. A5.1 Propagation models. A5.2 Mobility models. A5.3 Traffic models. 6 CRRM in Beyond 3G Systems. 6.1 Heterogeneous networks. 6.2 Radio Access Networks characterization. 6.3 Interworking and coupling among Radio Access Networks. 6.4 Flexible radio resource and spectrum management. 6.5 CRRM algorithm implementation. References. Index.
John.Wiley.Sons.Radio.Resource.Management.Strategies.in.UMTS.Jul.2005.eBook-LinG.part1.rar
976.56 KB, 下载次数: 32 , 下载积分: 资产 -2 信元, 下载支出 2 信元
01
发表于 2007-2-11 13:18:35 | 显示全部楼层
回复 #1 saileryt 的帖子
发表于 2007-2-19 16:35:42 | 显示全部楼层
Wonderful book
Wonderful book
发表于 2007-2-20 14:31:56 | 显示全部楼层
Goof Good
Goof Good
发表于 2009-4-28 22:29:48 | 显示全部楼层
书很好   回帖下
发表于 2010-1-18 11:19:45 | 显示全部楼层
where is the other parts?
发表于 2010-3-16 16:52:45 | 显示全部楼层
缺少其他部分 : (
发表于 2012-8-13 17:52:50 | 显示全部楼层
Let me see!
GMT+8, 2025-12-22 12:16 , Processed in 0.021882 second(s), 8 queries , Gzip On, Redis On.
