查看: 3392|回复: 4
[求助] HHNEC DRC RULE请教
发表于 2013-7-10 18:21:24 | 显示全部楼层 |阅读模式
//|Metal slot  CHECKS |
GROUP GME1ST ME1.slot?
U_LAYER = (((ME1 OR ME2) OR ME3) OR TOPME) OR ACT
CHIP_S = AREA CHIP <= 100000000
CHIP_L = AREA CHIP > 100000000
CORNER_T1_S = INT (FRAME INTERACT CHIP_S) < 525 ABUT == 90 REGION
CORNER_T2_S = EXTENTS CORNER_T1_S
CORNER_T3_S = CORNER_T2_S NOT COIN EDGE FRAME
CORNER_T4_S = CORNER_T2_S COIN EDGE FRAME
CORNER_T5_S = INT CORNER_T3_S < 400 ABUT == 90 REGION
CORNER_T6_S = INT CORNER_T4_S < 125 ABUT == 90 REGION
CORNER_T7_S = EXTENTS CORNER_T6_S
CORNER_AREA_S = (CORNER_T2_S NOT CORNER_T5_S) NOT CORNER_T7_S
CORNER_T1_L = INT (FRAME INTERACT CHIP_L) < 1050 ABUT == 90 REGION
CORNER_T2_L = EXTENTS CORNER_T1_L
CORNER_T3_L = CORNER_T2_L NOT COIN EDGE FRAME
CORNER_T4_L = CORNER_T2_L COIN EDGE FRAME
CORNER_T5_L = INT CORNER_T3_L < 700 ABUT == 90 REGION
CORNER_T6_L = INT CORNER_T4_L < 350 ABUT == 90 REGION
CORNER_T7_L = EXTENTS CORNER_T6_L
CORNER_AREA_L = (CORNER_T2_L NOT CORNER_T5_L) NOT CORNER_T7_L
THERMAL_CHECK_A { @ Active and metal are not allowed in region A
((U_LAYER INTERACT CORNER_T7_S) AND CORNER_T7_S) NOT (ME_ALL OR PTAP_DON)
((U_LAYER INTERACT CORNER_T7_L) AND CORNER_T7_L) NOT (ME_ALL OR PTAP_DON)
上面是HHNEC BCD180工艺库的DRC RULE FILE中的一段内容,请问这段检查是什么意思?目前DRC只报了700多例THERMAL_CHECK_A 违例,请问这个是需要我修改版图还是可以交给foundry解决?感谢各位!
 楼主| 发表于 2013-7-11 09:45:33 | 显示全部楼层
各位大侠都去哪了- -求指点啊
发表于 2013-7-14 23:33:28 | 显示全部楼层
不好意思,没用过Nec的run deck。
发表于 2013-7-16 14:29:32 | 显示全部楼层
发表于 2013-7-16 19:13:00 | 显示全部楼层
回复 2# 2421212
    找HHNEC那边问问吧
GMT+8, 2025-12-18 00:45 , Processed in 0.025123 second(s), 4 queries , Gzip On, Redis On.
