查看: 3224|回复: 2
[原创] 测试pattern fail ,格式看不懂,请指教?
发表于 2013-7-8 11:04:37 | 显示全部楼层 |阅读模式
--------------------INFORMATION---------------------------
Device Name: YYG
Sub Test Name: Func_SPI
Pattern Name: npt1101_function_pattern_spi_130702[Header_SPI_0702].bin
--------------------DEFINE OF SYMBOLS---------------------
H : Indicates that the test passed with test pattern data of H.
/ : Indicates that the test failed (L was detected) with test pattern data of H.
\ : Indicates that the test failed (Z was detected) with test pattern data of H.
L : Indicates that the test passed with test pattern data of L.
. : Indicates that the test failed (H was detected) with test pattern data of L.
* : Indicates that the test failed (Z was detected) with test pattern data of L.
1 : Indicates that pattern data caused the driver to output 1.
0 : Indicates that pattern data caused the driver to output 0.
X : Indicates a Don't care pin.
Z : Indicates Tri - State passed.
- : Indicates Tri - State failed (H was detected) with test pattern data of Z.
_ : Indicates Tri - State failed (L was detected) with test pattern data of Z.
--------------------PATTERN DUMP--------------------------
P               PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP
i               AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA
n               DDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDD
.               110000000011111110111111110000100001000000000000000000000000010001111111011111111111111110000000000
.               459999999800000009111111118888577772222223331112222200000011760005555554344444533332222335555666665
.               708743210998765109987654306435232453567890122390123445678901642318956346351234767347845012165438709
.               ___________________________________________________________________________________________________
.               ITddddddddddddddddddddddddddddhddddThhhhhhhhhhhhhhhhhhhhhhhhdhhhhTThhhhCTRIIIOThhhhhhhhhhdddddddddd
.               NEDDDDDDDDDDDDDDDDDDDDDDDDPVHDSCDSSSDDDDDDDDDDDDDDDDDDDDDDDDSPVHDSSCDSSSXEMMMMSDDDDDDDDDDDDDDDDDDDD
.               T|BBBBBBBBBBBBBBBBBBBBBBBBCSSEDSCCDTBBBBBBBBBBBBBBBBBBBBBBBBDCSSETTSCDCS_S012|TSSSSSSSSSSSSSSSSSSSS
.               |0111122228911111101234567LYY|OXXLII111122228911111101234567OLYY|MMXXILPCX|||0MIIIIIIIIIIIIIIIIIIII
.               0367890123||012345||||||||KNN1|||||N67890123||012345|||||||||KNN1OO|||||L|0003O____________________
.               37||||||||11||||||00001111|CC4000000||||||||11||||||111111110|CC6DD00000K06333DDDDDDDDDCCDDDDDDDDCC
.               8 1111111189111111445566661||032222|11111110871111116668988820||81244443|3054 000112233LL00112233LL
.                 555554449188887789015713400 6315704444433026755555602804609411 ||1032902    |PNPNPNPNKKPNPNPNPNKK
.                 86420864  571379        222      597531972  897531         476 00     0     0||||||||PN||||||||PN
.                                          86      5                          04 44     0     400000000||00000000||
.        65           766565555000000111100
.        21632943553175539710
Vector No        87        19       Instruction
0               LLLLLLLLLLLLLLLLLLLLLLLLLLLLLL.HLHL10000000000000000000000000X11100100111000110HH11111111HHHHHHHHHH        NOOP Rate=0  Ignore=Disable
16135           LLLLLLLLLLLLLLLLLLLLLLLLLLHLLL/HLHL10000000000000000000000000X00000010011100110HH11111111HHHHHHHHHH        NOOP Rate=0  Ignore=Disable
16137           LLLLLLLLLLLLLLLLLLLLLLLLLLHLLL/HLHL10000000000000000000000000X00000010011100110HH11111111HHHHHHHHHH        NOOP Rate=0  Ignore=Disable
16138           LLLLLLLLLLLLLLLLLLLLLLLLLLHLLL/HLHL10000000000000000000000000X00000010011100110HH11111111HHHHHHHHHH        NOOP Rate=0  Ignore=Disable
16139           LLLLLLLLLLLLLLLLLLLLLLLLLLHLLL/HLHL10000000000000000000000000X00000010011100110HH11111111HHHHHHHHHH        NOOP Rate=0  Ignore=Disable
16140           LLLLLLLLLLLLLLLLLLLLLLLLLLHLLL/HLHL10000000000000000000000000X00000010011100110HH11111111HHHHHHHHHH        NOOP Rate=0  Ignore=Disable
 楼主| 发表于 2013-7-9 14:43:18 | 显示全部楼层
好吧,看懂了,竖着看
发表于 2014-1-27 09:49:43 | 显示全部楼层
看不懂
GMT+8, 2025-12-29 12:46 , Processed in 0.017053 second(s), 7 queries , Gzip On, Redis On.
