This section describes new features, changes, and enhancements in the StarRC
Reference Methodology version G-2012.06.
* The simultaneous multicorner flow has been added.
This flow considers process and temperature corners simultaneously and is
available for both distributed processing and Rapid3D field solver extraction.
To enable this flow, select TRUE for the Simultaneous Multicorner Extraction option
in RMgen.
* When you enable simultaneous multicorner extraction, the capability to list
the parasitics for all corners in a single netlist is enabled by default.
To enable or disable this capability, set the SMC Merge Netlist option in
RMgen. This option is available only when simultaneous multicorner extraction
is enabled.
This release provides enhancements in the Lynx-Compatible reference
methodology flow. For information about these enhancements, see the file
named Release_Notes.LynxCompatible-RM.txt.
STARRC-RM_G-2012.06.tar
(30 KB , 下载次数:
203 )
