楼主: wangshanyi
[求助] 求救~~用HSPICE 做电路设计仿真
 楼主| 发表于 2013-6-18 23:41:51 | 显示全部楼层
回复 9# hszgl
这个是我HSPICE 的.LSI文件
**diagnostic** rebuilding matrix with pivot option
**diagnostic** rebuilding matrix without pivot option
1****** HSPICE  --  A-2007.09  32-BIT    (Aug 28 2007) 21:17:13 06/18/2013 winnt
en nmos device characteristics
  ******  operating point information      tnom=  25.000 temp=  25.000
***** operating point status is all       simulation time is     0.
    node    =voltage      node    =voltage      node    =voltage
+0:1       =   2.5000  0:2       =   1.9427  0:3       =   1.5000
+0:4       =   1.5000  0:5       =   1.1677  0:6       =   1.1677
+0:7       = 416.8454m 0:8       =   1.1677  0:9       =   1.5000
+0:10      =   1.5000  0:11      =   0.      0:12      =   0.
****  voltage sources
subckt
element  0:vdd      0:vin1     0:vin2     0:v1
  volts      2.5000     1.5000     1.5000     0.
  current   -1.4006m    0.         0.         0.
  power      3.5016m    0.         0.         0.
     total voltage source power dissipation=    3.5016m       watts
***** current sources
subckt
element  0:idc
  volts    557.2792m
  current   50.0000u
  power    -27.8640u
     total current source power dissipation= -27.8640u       watts
**** resistors
subckt
element  0:r1       0:r2
  r value    5.0000k    5.0000k
  v drop   -67.7862p   67.7856p
  current  -13.5572f   13.5571f
  power    9.190e-25  9.190e-25
**** voltage-controlled voltage sources
subckt
element  0:e1       0:e2
  volts      0.         0.
  current    0.         0.
**** mosfets
subckt
element  0:m1       0:m2       0:m3       0:m4       0:m5       0:m6
model    0:nch3.3   0:nch3.3   0:pch3.2   0:pch3.2   0:nch3.2   0:nch3.10
region     Saturati   Saturati   Saturati   Saturati     Linear   Saturati
  id       675.3152u  675.3152u -675.3152u -675.3152u    1.3506m   50.0000u
  ibs     -966.6479a -966.6479a  7.877e-20  7.877e-20 -2.176e-19 -1.100e-20
  ibd     -971.7764a -971.7764a  449.2208f  449.2208f -118.9518a -430.7781f
  vgs        1.0832     1.0832    -1.3323    -1.3323     1.9427     1.9427
  vds      750.8543m  750.8543m   -1.3323    -1.3323   416.8454m    1.9427
  vbs     -416.8454m -416.8454m    0.         0.         0.         0.
  vth      989.5154m  989.5154m -704.0881m -704.0881m  771.8126m  762.8190m
  vdsat    124.2526m  124.2526m -491.1931m -491.1931m  894.7095m  902.6288m
  vod       93.6392m   93.6392m -628.2122m -628.2122m    1.1709     1.1799
  beta     101.5385m  101.5385m    4.3530m    4.3530m    3.8910m   95.6093u
  gam eff  974.2384m  974.2384m  730.3339m  730.3339m  856.7069m  838.3377m
  gm         8.7832m    8.7832m    1.9318m    1.9318m    1.2039m   72.1471u
  gds       24.3931u   24.3931u    5.4955u    5.4955u    2.2733m  214.1663n
  gmb        3.4621m    3.4621m    1.0511m    1.0511m  683.4160u   34.0973u
  cdtot    323.1676f  323.1676f  137.7728f  137.7728f  312.5490f    1.1052f
  cgtot    981.5397f  981.5397f  914.2005f  914.2005f  378.9782f    8.0129f
  cstot      1.2501p    1.2501p    1.2242p    1.2242p  430.6129f   10.4732f
  cbtot    863.3637f  863.3637f  624.4559f  624.4559f  222.2013f    5.6438f
  cgs      748.2676f  748.2676f  834.6034f  834.6034f  245.7040f    6.8965f
  cgd      101.4535f  101.4535f   41.6301f   41.6301f  135.2573f  309.7065a
  ******  ac analysis                      tnom=  25.000 temp=  25.000
a
      freq       gain1_av0
(a       )     -20.0000        0.           20.0000       40.0000      60.0000
  100.0000    31.642 -+------+------+------+------+------+a-----+------+------+-
  125.8925    31.642  +      +      +      +      +      +a     +      +      +
  158.4893    31.642  +      +      +      +      +      +a     +      +      +
  199.5262    31.642  +      +      +      +      +      +a     +      +      +
  251.1886    31.642  +      +      +      +      +      +a     +      +      +
  316.2278    31.642  +      +      +      +      +      +a     +      +      +
  398.1072    31.642  +      +      +      +      +      +a     +      +      +
  501.1872    31.642  +      +      +      +      +      +a     +      +      +
  630.9573    31.642  +      +      +      +      +      +a     +      +      +
  794.3282    31.642  +      +      +      +      +      +a     +      +      +
    1.0000k   31.642 -+------+------+------+------+------+a-----+------+------+-
    1.2589k   31.642  +      +      +      +      +      +a     +      +      +
    1.5849k   31.642  +      +      +      +      +      +a     +      +      +
    1.9953k   31.642  +      +      +      +      +      +a     +      +      +
    2.5119k   31.642  +      +      +      +      +      +a     +      +      +
    3.1623k   31.642  +      +      +      +      +      +a     +      +      +
    3.9811k   31.642  +      +      +      +      +      +a     +      +      +
    5.0119k   31.642  +      +      +      +      +      +a     +      +      +
    6.3096k   31.642  +      +      +      +      +      +a     +      +      +
    7.9433k   31.642  +      +      +      +      +      +a     +      +      +
   10.0000k   31.642 -+------+------+------+------+------+a-----+------+------+-
   12.5893k   31.642  +      +      +      +      +      +a     +      +      +
   15.8489k   31.642  +      +      +      +      +      +a     +      +      +
   19.9526k   31.642  +      +      +      +      +      +a     +      +      +
   25.1189k   31.642  +      +      +      +      +      +a     +      +      +
   31.6228k   31.642  +      +      +      +      +      +a     +      +      +
   39.8107k   31.642  +      +      +      +      +      +a     +      +      +
   50.1187k   31.642  +      +      +      +      +      +a     +      +      +
   63.0957k   31.642  +      +      +      +      +      +a     +      +      +
   79.4328k   31.642  +      +      +      +      +      +a     +      +      +
  100.0000k   31.642 -+------+------+------+------+------+a-----+------+------+-
  125.8925k   31.642  +      +      +      +      +      +a     +      +      +
  158.4893k   31.642  +      +      +      +      +      +a     +      +      +
  199.5262k   31.642  +      +      +      +      +      +a     +      +      +
  251.1886k   31.642  +      +      +      +      +      +a     +      +      +
  316.2278k   31.642  +      +      +      +      +      +a     +      +      +
  398.1072k   31.642  +      +      +      +      +      +a     +      +      +
  501.1872k   31.642  +      +      +      +      +      +a     +      +      +
  630.9573k   31.642  +      +      +      +      +      +a     +      +      +
  794.3282k   31.642  +      +      +      +      +      +a     +      +      +
    1.0000x   31.642 -+------+------+------+------+------+a-----+------+------+-
    1.2589x   31.641  +      +      +      +      +      +a     +      +      +
    1.5849x   31.641  +      +      +      +      +      +a     +      +      +
    1.9953x   31.640  +      +      +      +      +      +a     +      +      +
    2.5119x   31.638  +      +      +      +      +      +a     +      +      +
    3.1623x   31.635  +      +      +      +      +      +a     +      +      +
    3.9811x   31.631  +      +      +      +      +      +a     +      +      +
    5.0119x   31.625  +      +      +      +      +      +a     +      +      +
    6.3096x   31.615  +      +      +      +      +      +a     +      +      +
    7.9433x   31.599  +      +      +      +      +      +a     +      +      +
   10.0000x   31.574 -+------+------+------+------+------+a-----+------+------+-
   12.5893x   31.534  +      +      +      +      +      +a     +      +      +
   15.8489x   31.473  +      +      +      +      +      +a     +      +      +
   19.9526x   31.376  +      +      +      +      +      +a     +      +      +
   25.1189x   31.228  +      +      +      +      +      +a     +      +      +
   31.6228x   31.003  +      +      +      +      +      +a     +      +      +
   39.8107x   30.668  +      +      +      +      +      a      +      +      +
   50.1187x   30.185  +      +      +      +      +      a      +      +      +
   63.0957x   29.516  +      +      +      +      +      a      +      +      +
   79.4328x   28.629  +      +      +      +      +     a+      +      +      +
  100.0000x   27.514 -+------+------+------+------+----a-+------+------+------+-
  125.8925x   26.183  +      +      +      +      +   a  +      +      +      +
  158.4893x   24.665  +      +      +      +      +  a   +      +      +      +
  199.5262x   22.999  +      +      +      +      + a    +      +      +      +
  251.1886x   21.224  +      +      +      +      +a     +      +      +      +
  316.2278x   19.373  +      +      +      +      a      +      +      +      +
  398.1072x   17.471  +      +      +      +    a +      +      +      +      +
  501.1872x   15.534  +      +      +      +   a  +      +      +      +      +
  630.9573x   13.577  +      +      +      +  a   +      +      +      +      +
  794.3282x   11.608  +      +      +      +a     +      +      +      +      +
    1.0000g    9.632 -+------+------+------a------+------+------+------+------+-
    1.2589g    7.656  +      +      +    a +      +      +      +      +      +
    1.5849g    5.684  +      +      +   a  +      +      +      +      +      +
    1.9953g    3.721  +      +      +  a   +      +      +      +      +      +
    2.5119g    1.777  +      +      +a     +      +      +      +      +      +
    3.1623g -138.619m +      +      a      +      +      +      +      +      +
    3.9811g   -2.010  +      +     a+      +      +      +      +      +      +
    5.0119g   -3.814  +      +   a  +      +      +      +      +      +      +
    6.3096g   -5.520  +      +  a   +      +      +      +      +      +      +
    7.9433g   -7.093  +      + a    +      +      +      +      +      +      +
   10.0000g   -8.492 -+------+a-----+------+------+------+------+------+------+-
b
          ***** job concluded
  ******  job statistics summary           tnom=  25.000 temp=  25.000
           total memory used        202 kbytes
  # nodes =      25 # elements=      18
  # diodes=       0 # bjts    =       0 # jfets   =       0 # mosfets =       6
  # va device =       0
    analysis           time    # points   tot. iter  conv.iter
    op point           0.02           1          28
    ac analysis        0.04          81          81
    readin             0.06
    errchk             0.01
    setup              0.00
    output             0.00
发表于 2013-6-19 12:44:47 | 显示全部楼层
回复 10# wangshanyi
   我说的是ICMR(input common model range),不是cmrr。你这里只有op point和AC的结果。   把放大器结成单位增益,input 从gnd 扫到vdd。输出曲线和m5管的电流曲线贴上来看一下。
  你也可以参考allen的书上看下怎么仿这些参数。
发表于 2013-6-19 22:46:04 | 显示全部楼层
回复 1# wangshanyi
    多少钱,我找人帮你搞定,电路不是这样设计的。
发表于 2013-6-20 11:14:29 | 显示全部楼层
回复 13# xxl04120184
   人家交个作业而已。你身为版主,不引导指点新人也就算了。一上来开口就要钱?什么素质?还“找人帮你搞定”,说明这么简单的题目你也搞不定咯?那你还有脸在这混?
发表于 2013-6-20 15:20:15 | 显示全部楼层
回复 14# hszgl
   非常支持~
 楼主| 发表于 2013-6-20 18:57:31 | 显示全部楼层
回复 13# xxl04120184
    额~不用麻烦了~谢谢你的好意~
 楼主| 发表于 2013-6-20 18:58:57 | 显示全部楼层
回复 12# hszgl
    恩~其实HSPICE 我到现在还不太会用~我觉得我应该先好好看看书~有些东西连原理还都不清楚
 楼主| 发表于 2013-6-20 19:35:59 | 显示全部楼层
回复 14# hszgl
我发现这个电路,要把M5先放在饱和区,然后才能调上面的管子,不然M1 管子大小一变就不对了。
我重新做了一下,好像现在比较靠谱了。
你说的M5的电流是这个吗?
发表于 2013-6-20 22:06:08 | 显示全部楼层
回复 18# wangshanyi
    所有的管子,包括m5都是一定要在饱和区的,没注意看你的out文档。看摆幅很容易,输入端一端接共模电平,另一端接个正弦信号,看输出的峰峰值(接近方波)就是。共模输入范围的限制就是要求所有管子都工作在饱和区。单端输出的接成follower就可以了,输入端扫0到vdd,看out能够follow的范围,再检测尾电流管的电流,有一小段区间输出还是能follow,但是尾电流管已经进入截止区,即超出了共模电平范围。你的是双端输出的,可以认为是简单的全差分结构,测量方式有所不同。可以在论坛里搜“全差分运放仿真”,找些资料做参考。。
 楼主| 发表于 2013-6-20 23:06:56 | 显示全部楼层
回复 19# hszgl
恩~谢谢。输出摆幅已经达到要求750mVp,p了,这个也算完成了。。。谢谢你一直在回我的贴。
GMT+8, 2025-11-25 06:15 , Processed in 0.021032 second(s), 5 queries , Gzip On, Redis On.
