查看: 3011|回复: 1
[求助] VCS后仿问题
发表于 2013-6-5 10:30:58 | 显示全部楼层 |阅读模式
最近刚学VCS做后仿真,为什么反标sdf后,在vcs编译时提示很多类似如下的warning:Warning-[SDFCOM_ICBF] Instance cannot be found
./result/test_ip.sdf, 16
  SDF Warning: Instance tb_top of type "hierarchy_top" cannot be found .
./result/test_ip.sdf, 120238
  SDF Warning: Instance U9928 of type "INVX1" cannot be found under  tb_top
./result/test_ip.sdf, 120247
  SDF Warning: Instance U9927 of type "INVX1" cannot be found under  tb_top
./result/test_ip.sdf, 120256
  SDF Warning: Instance U9926 of type "INVX1" cannot be found under  tb_top
./result/test_ip.sdf, 120265
  SDF Warning: Instance U9925 of type "INVX1" cannot be found under  tb_top
./result/test_ip.sdf, 120274
  SDF Warning: Instance U9924 of type "INVX1" cannot be found under  tb_top
请帮忙解惑,谢谢!
发表于 2013-6-5 12:46:43 | 显示全部楼层
Check your tb_top.v
GMT+8, 2025-12-24 03:34 , Processed in 0.015047 second(s), 5 queries , Gzip On, Redis On.
