查看: 9523|回复: 3
[求助] lvs报错,layout比soure多了几条nets
发表于 2013-6-3 18:13:15 | 显示全部楼层 |阅读模式
report在这里
Error:    Different numbers of nets (see below).
  Error:    Connectivity errors.
LAYOUT CELL NAME:         my_test
SOURCE CELL NAME:         my_test
INITIAL NUMBERS OF OBJECTS
                Layout    Source         Component Type
Ports:             22        22
Nets:             722       717    *
Instances:        673       657    *    MN (4 pins)
                   675       663    *    MP (4 pins)
Total Inst:      1348      1320
NUMBERS OF OBJECTS AFTER TRANSFORMATION
Ports:             22        22
Nets:             373       368    *
Instances:         12        12         MN (4 pins)
                    12        12         MP (4 pins)
                    12        12         SPUP_2_1 (4 pins)
                   187       187         _invv (4 pins)
                     2         2         _invx2v (4 pins)
                    88        88         _nand2v (5 pins)
                    22        22         _nor2v (5 pins)
                    12        12         _sdw3v (5 pins)
                    96        96         _smn2v (4 pins)
                    96        96         _smp2v (4 pins)
Total Inst:       539       539
       * = Number of objects in layout different from number in source.
                                 INCORRECT OBJECTS
LEGEND:
  ne  = Naming Error (same layout name found in source
        circuit, but object was matched otherwise).
                                   INCORRECT NETS
DISC#  LAYOUT NAME                                               SOURCE NAME
  1    Net 133                                                   n30
           155
  2    Net 66                                                    N29
           131
  3    Net 83                                                    N33
           146
  4    Net 75                                                    n31
           125
  5    Net 74                                                    n32
           59
                               INFORMATION AND WARNINGS
                  Matched    Matched    Unmatched    Unmatched    Component
                   Layout     Source       Layout       Source    Type
   Ports:              22         22            0            0
   Nets:              373        368            0            0
   Instances:          12         12            0            0    MN(N12)
                       12         12            0            0    MP(P12)
                       12         12            0            0    SPUP_2_1
                      187        187            0            0    _invv
                        2          2            0            0    _invx2v
                       88         88            0            0    _nand2v
                       22         22            0            0    _nor2v
                       12         12            0            0    _sdw3v
                       96         96            0            0    _smn2v
                       96         96            0            0    _smp2v
   Total Inst:        539        539            0            0
1.这是因为什么原因造成的呢?
2.我在设置global net connections的时候,connection list是空的。怎么回事呢?
发表于 2013-6-3 18:53:47 | 显示全部楼层
两个办法:
1,DC出网表的时候就避免同时存在N和n
2。LVS验证的时候区分大小写。
 楼主| 发表于 2013-6-3 19:14:37 | 显示全部楼层
回复 2# damonzhao
   果然有这个大小写的问题。谢谢!
发表于 2018-5-6 19:14:33 | 显示全部楼层
我也是layout比source多了几个nets,请问lvs怎么区分大小写,还不会
GMT+8, 2025-10-8 18:34 , Processed in 0.019073 second(s), 5 queries , Gzip On, Redis On.
